Question about Mitsubishi VS-60805 60" Rear Projection Television
A double picture mostly in the corners!!!
Most of the screen is out of focus but the corners are the worst. The top of the screen is the shadow makes a U shape while at the the bottom it makes a reverse U. Not good. Happens about four to five minutes after turning set on. Help please!!
  • nathanle10 Oct 20, 2008
    Thank you. I will get that done!!
  • 905 Answers
Sorry but butoxige is wrong , this is a conversion problem , it is a chip that controls the color alignmrnt , vertical and horizontal to the crt
the problem you are describing is common amongst all projection televisions , it is a STK chip
you can see an example here
http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/a6717b3819c6a23485256a1c00529259/5561146d03eb3f53852572fa0002478b?OpenDocument
Posted on Oct 20, 2008
  • 77 Answers
It sounds like you you just need to get it refocused. most any repair person can do this and its relatively inexpensive
I have a 50DX10B, I believe was manufactured in July 2002. About a month ago the screen became distorted out of no where while I was watching it, and I gave the screen a little smack, (probably not the...
Replace or resolder your convergance IC's. What is a common problem is over time the heat emitted by the chips weakens the solder joints on the circuit board. If your lucky just a resolder job is all it needs.
Sep 04, 2011 | Hitachi 50DX20B 50" Rear Projection...
Shadows in top right and left hand corner of picture
If you know what you're doing - why not. Most probably something has got loose inside the lens and needs to be fixed.
May 28, 2010 | Nikon COOLPIX P80 Digital Camera
Our television just began having what looks like a 'double screen'...or the picture has a 'shadow'...and also looks as though the entire screen 'curves' ..at the top and bottom of the screen it is...
Hi
Thanks for using FixYa. First of all please check whether all the cables from your dish network are fine and connected firmly. If yes then you'll need to pull off the front of the TV, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage the tube. So you need to do only a small adjustment. Turn the color off on the TV and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittent blue picture tube, a bad blue driver transistor on the CRT board, a bad connection on the blue CRT board or a problem in the RGB coming from the video jungle IC. The price to resolve the issue will most likely run you about 300 to 500 bucks, unless it is the picture tube.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Sony Televison & Video
Double Vision & Bowed Screen
Chances are that the convergence amps are bad.
If those are mounted on a separate board, replacing the board would be the easiest thing to do. Running the magic focus or touching up the convergence in the customer menu may be required.
May 04, 2009 | Samsung HCN653W 65" Rear Projection...
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Yellow at the top, double vision, blurr
Good Day, turott1;
You need repair in the convergence circuit, purchase KIT 10. You can buy this at B&D ENTERPRISES, at 1-800-458-6053.
Good Luck, big IRISH.
Dec 30, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Convergence images?
The blue picture tube of a projection tv is usually the weakest in ability to focus and in most cases loses its focus ablility before the red and green. Connect a cross-hatch generator to the rf inputs of the unit and check to see which areas are most out of convergence. The corners are usually the worst. HD will always bring out the slightest imperfections. If the unit was totally out of convergence, I would have suggested replacing the convergence IC'S.In my experience with rear projection, your problem is normal wear . You could conceivably improve the picture by adjusting the blue focus on the screen focus block. Scrivitron
Jun 15, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
