Question about West Bend 84496 6-Quart Slow Cooker
Using a power inverter
I tried connecting the pot to a 12v/120v power inverter. I used a 400w model which should provide ample power. The unit started up fine but after a few mniutes it went dead and has remained so. What failed? and why?
Have you checked the fuse at the back . 400w I would have thought is not big enough
Posted on Feb 01, 2009
Looking for instructions on how to use or a manual
This is the link on FAQ's for Crock Pots & Slow Cookers.
http://www.crock-pot.com/service-%26-support/product-support/product-faqs/product-faqs.html
I will be able to help you with the Manual, if you can provide me the exact Model # of the unit that you're using.
Thank you.
Aug 27, 2014 | Crock Pots & Slow Cookers
Where can i buy extra pot for ge 3 combo crockpot
In the manufacturing world most times they don't bother trying to stock parts like that. You just have to buy another used or new unit or buy another model
Dec 02, 2013 | GE 106851 6-Quart
I have a Rival Crock Pot slow cooker. I do not have the directions to use the meat probe. What dials do I set?
The Instruction Manuals for Rival Slow Cookers are available on-line:
http://www.crock-pot.ca/CustomerService.aspx?id=man
For some reason it does not seem easy to match up model numbers; however, I believe the manual posted for the SCVP600HSS will provide the information you need for use of the temperature probe:
http://www.crock-pot.ca/Manuals/MANUALS/SCVC600SS-CN_43_41977702.PDF
Refer to pages 9 -11 of the PDF.
Apr 02, 2011 | Rival SC7600 6-Quart
Just been given crock pot with 3 settings can you explain them no manual came with pot
It sure would help us to help you if you could get the model number off of the bottom of the unit. I can probably locate a user's manual with that information. Try this site to locate the manual: (my best guess without a model number)
http://safemanuals.com/314159.php?k=84c8d7db0922eceeab89e8e236b92e45&ID=2854106&q=CROCK%20POT%20SMART%20POT
(209k)
Find the little blue print that says enter security code and then you can dounload the manual.
The settings should be OFF High 4 High 6, Low 8 Low 10 and warm.
1. Place food in stoneware according to recipe.
2. Plug in Smart-Pot™ slow cooker. The Power light will begin to flash
indicating that the unit is plugged in, but not turned on.
HOW TO PROGRAM YOUR SMART-POT™ (CONT.)
3. Push the Cook Time button to scroll through the timed cooking
options. Push once and the 4 hour light will illuminate, twice and the
6 hour light will come on, etc. Select the time based on the length of
time indicated in the recipe. Two time options are usually given. The 4
and 6 hour settings are the HIGH temperature setting and may be
used when you want your food done quicker. The 8 and 10 hour
settings correspond to the LOW temperature setting and is used for all
day cooking. In addition your Smart-Pot™ can be set to the Warm
Setting by scrolling through the timed cooking options until the warm
light illuminates.
NOTE: The Warm setting is for keeping already hot food warm. Do not use
the warm setting to cook or reheat food.
4. When the cooking time is completed, the Smart-Pot™ slow cooker will
automatically shift to the Warm setting and the Warm light will come
on. NOTE: We do not recommend using the Warm setting for more
than 4 hours.
5. To turn the Smart-Pot™ off push the OFF button. Unplug unit from the
wall outlet.
6. For other recipes that give a range of times, select the time closest
to the setting on your Smart-Pot™. For instance a recipe calling for
cooking time of 7 to 9 hours on LOW, set your Smart-Pot™ to 8 hours.
NOTE: If power goes off then power light will blink and settings must be
reset. If cook time is changed before the cycle is complete the time will
reset to the new setting.
Thanks for choosing FixYa,
Kelly
Mar 04, 2011 | Rival 38601 Smart Pot 6-Quart
How can i switch my rival programmable crockpot to warm? It was cooking too long and I'd like to switch it
A crock pot is an ALL DAY cooking methodology and should not be altered. Fire and personal injury are possible results.
Oct 17, 2010 | Rival 38601 Smart Pot 6-Quart
Model 3755 5.5 qt. Crock Pot base unit burned out
for what they get at a repair versus a replacement you better start looking, it will cost you more just to get an estimate than a new unit will cost
Oct 26, 2009 | Rival 3755 5.5-Quart
Replacement for the crock pot insert for model 3355
I found a phone number embossed on the crockpot. It's the number to Rival. I called them and they said I could get a new insert ($10 + $8.50 ship), but prewsently out of stock. Should be available in about a month.
David
Mar 18, 2008 | Rival 3355 5-Quart
It wont heat up and all the lights just keep blinking
I have the same problem EVERY time I want to use the crock pot. My solution has be patience. I find that if I turn it on, and the light blinks, but when i click it it will blink on 4 hours, then go back to the blinking light. By keeping the crock pot plugged in and off for about 10-15 minutes I was then able to set the crockpot up for cooking. As if the capacitors inside the unit needed power stored in them from the wall.
Dec 21, 2007 | Rival 5865-W 6.5-Quart Slow Cooker
Green light is blinking, but I am unable to trun the power on.
rival smart pot 38651 crock pot all light blinking
to reset this you need to hold both thye right and left button for 30 seconds. the cause of this is from unpluging the unit when it is on also a power failure will cause this. if this does not work hold all four buttons in. they only tell you this if you get the right person at Jarden Consumer Solutions
www.crock-pot.com
Oct 30, 2007 | Rival 38601 Smart Pot 6-Quart
West Bend 84496 6-Quart Slow Cooker Logo
235 people viewed this question
Top West Bend Crock Pots & Slow Cookers Experts
Steve
tsalagi152
Andrew Taylor
Andrew Taylor
Are you a West Bend Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
