Question about Xerox XDL-33D Black and White Copier
XDL -33D B&W copier - "insert card"
I purchased a used Xerox SCL-33D Black and White copier. There had been a copy tracking device for which was removed. The screen now reads, "Insert Card". I do not know how to turn this feature off, whether it is referring to the Xerox Card or key counter needing to be loaded, or whether it is for the access device which has been removed. How do I turn this feature off or re-format for general use?
5 Suggested Answers
  • 2072 Answers
SOURCE: Xerox Workcenter 222 toner card
There is a card that should come with a cartridge. It slides into the slot on the side of the machine to reset the toner cartridge count.
I don't know of a way to reset the count without a card.
Wish I had a better answer, but the card is encoded to reset the machines toner count in the software.
Posted on May 06, 2008
vmachlis
  • 7 Answers
SOURCE: Xerox XC 1020 copier code H4
With "H4" flashing press:
1.Clear button
2.Auto button then again
3.Clear button
4.Auto button
It should be done quickly. If it's done quickly enough all lights on display should go off.
5.Enter number 14 (as if you are making 14 copies).
6. Press START/COPY button.
The machine goes back to normal. If not, thermistor on the fuser (heater) should be replaced.
Posted on Dec 21, 2008
pateltraders
  • 35 Answers
SOURCE: insert toner card for xerox phser 3100mfp
we have solutions now just install one device moduler. and printer work life time.
msn: howtorefill@hotmail.com
skype: indianrefiller
www.chipresetters.com
email: pateltraders@gmail.com
Posted on Oct 01, 2009
  • 525 Answers
SOURCE: i have xerox phaser 3100
You have to buy a toner card and inserted in slot bottom of control panel.
Posted on Jan 20, 2011
How do I turn off copy-card default on xerox copycenter c123
http://www.support.xerox.com/support/copycentre-c123-c128/support/enus.html
This is how to turn off Auditron but this is the same menu as "foreign interface device" or copy card.
Jan 17, 2014 | Xerox CopyCentre C123 Copier
My xerox xc1040 keep streaking across the page, this is the second cartrige and is a few years old. This machine has not been used very much for its age. I take the cartrige out and shake it around, wipe...
You are going to need a new drum unit. This is the cartridge that is located right next to your toner cartridge. What is happening is the drum bleaning blade has gone bad and is not cleaning the drum properly. You can have these rebuilt but with parts and labor they usually end up costing more than just replacing the whole unit yourself. You can find them on the internet for around $125.00. Make sure if you order one that it is the whole unit not just the drum. For example a drum alone is around $40 - $50 VS the $125 for the cartridge.
Good Luck and Thank You for using Fixya.
Nov 12, 2010 | Xerox XDL-33D Black and White Copier
Have XDL33 Copier. Has been out of service for a while because when turn it on get u42 error code. Had this code several times before while it was under maintenance contract and only took tech a few...
Hello sir; Yes, you can do it by youself,just follow my instruction;
Open front door , hold 0 while you turn on power then enter 50 press start key, enter 20 press start key again, then close door turn power off and back on.
Aug 20, 2009 | Xerox XDL-33D Black and White Copier
Xerox Copier Model XC1020
if the paper is black and the copies are coming out there is a problem with
1) the drum,
2) the transfer unit--- the unit under the drum, with thin wires,
Jan 08, 2009 | Xerox CopyCentre C20 Black and White...
Xerox XC820 Copy Machine
three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at jagpal_65@yahoo.com
Dec 25, 2008 | Xerox XDL-33D Black and White Copier
Xerox xc 830
pls check ur machine ros assembly unit. i think the ros assay geting dust or its geting failed.
Jul 23, 2008 | Xerox Office Equipment & Supplies
Xerox Copier XC356 gives only all black copies.
WITH THIS PRINTER ITS CHEAPER TO REPLACE THAN REPAIR SOUNDS LIKE THE LED OR ILLUMINATIN LAMP IS BLOWN
Jan 23, 2008 | Xerox XC356 Copier
How to repair with Toshiba copier 2060
lan lam... "insert key counter" means that the machine has an external control device. Usually a small box the size of a pack of ciggerettes or smaller) with a mechanical counter that needs to be inserted into a port on the machine in order for it to operate. Companies used this to "control" and/or track machine usage by department or person. It may be that your machine has one but it's not inserted well enough, or you are missing the counter comepletely. If you don't have one of these control devices, you will probably need a certified technician to come out and disable this feature.
Oct 09, 2007 | Kyocera RI-3530 Black and White Copier
Xerox XDL-33D Black and White Copier Logo
35 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
