Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
PT-50LC14-K panasonic TV, Problems with picture, TV is almost three years old, about to months ago, there was big POP and then went off, but I could turn on TV and everything looks good, but after couple of weeks, the picture start having som countours around bright colores, such as lamp. And for high defination, the faces start having dark spots and light spots. and countors on it..so I am wantching through VCR, which the picture is much better, even though is not HD anymore.. Can you help me to identify the problem, thanks
I change the lamp, but the problem is still not solved yet. I still have the same problem with TV..
Posted on Nov 09, 2008
Colors need to be calibrated by a technician
Posted on Dec 12, 2013
You need to change the lamp which costs $300.
Posted on Oct 22, 2008
I have a panasonic PT-50LC14. the tv will turn on, but there is no picture. do i need a new lamp or bulb?
It is possible if over two thousand hours of use or two years, I would suggest at least removal and inspection to see if lamp shattered.
Sep 03, 2012 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
May 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
No picture or sound
first unplug the unit let it cool down ....plug it back in then reset the counter....press (-) volume on the tv and while holding down press the pip/split button on the remote and that should reset the counter...
Jan 07, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Picture quality on PT-50LC14
clean out the housing (where the lamp is) the go through your menu and check the tv settings ie...color temp, picture, contrast, ect...try resetting it back to the default and go from there
Nov 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic dlp tv
I had the same problem a month ago. Open the front cover on the left side of the tv and undo the one screw to pull out the housing for the bulb. You will probably see it is shattered.
Sep 08, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Dead tv
Sounds like a power supply problem. I am sure that the pop is the fuse blown. If the fuse is blown, this means that there is a short somewhere. Rear projection TV are like LCD projectors. And all of them use Switch mode power supply. If you are lucky, there is a chance that a protection device (like a varistor) is sorted. This means that removing this, even without replacing will bring your TV to life, however... Most probably the power supply is defective.
May 22, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
492 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
