Question about Nokia Cell Phones
Nokia 6500 slide: keypad not working
Just had the LCD screen replaced. Keypad now not working. Have been asked to open the back via the four screws and check the wiring of keyboard to motherboard. Any idea how to open the back to reveal the back of keyboard after taking out four screws?
5 Suggested Answers
solutionzone
  • 86 Answers
SOURCE: nokia 6500 slide keypad problem and replacement off ice
Hi ,
you can go to the nearest mobile hardware point and checkout the mobile . they will repair. so any kind of problem then you can mail me.(susa.asha@gmail.com)
Posted on Mar 29, 2009
VinayT
  • 1884 Answers
SOURCE: Nokia 6500 slide. Device Not Recognized
If you go to Control Panel -> System -> HardWare and check USB controllers which shud give you a list of all USB ports. Below that you will find Wireless Communication Devices. In this you shud find all the modes your phone is installed as. Check if all these settings are present. Secondly, install PC Suite now that you have restores the system to an earlier date. Connect the phone and connect.
Posted on Jul 28, 2009
SOURCE: Trying to remove the slider on SGH-A737
To remove the slider mechanism, take out the 4 visible screws first (under the battery cover). Then on the back of the phone at the bottom, remove the 2 little rubber circles with a tiny flat head screwdriver to reveal 2 more screws, take those out. Take out the 2 screws on either side of the flex cable that is coming out just below the battery compartment. Next is the part that took me hours to figure out. L Beneath where the battery sits is a long oval shaped thing (=======) <- looks something like that (sorry I don't have pictures). This is actually a sticker. Peel this up and remove the 2 screws under it (keep the sticker intact becase you will need to replace it later). This will detach the slider from the phone. Make sure to gently disconnect the flex cable from the mainboard first.
From there you can see more screws that will help you take apart the sliding part of the phone to access the lcd screen if you need to replace it (which is what I was doing). It's pretty easy from there to get everything else apart. Make sure when you disconnect the cables from the back of the LCD screen, that you flip up the little release tabs on the connectors first.
  • 23 Answers
SOURCE: htc touch pro slide out keyboard not working
if the phone is less than 1 year old then yes it should
Posted on Aug 02, 2009
Nokia 6500 slide 0,*,# buttons r not working so plz give me solution.
my friend,
in that case, ur phone has a keypad malfunction... in most cases the history of a phone is either water damage or drop off...
if u know how to dismantle your phone check the keypad membrane see if it is corroded or not... test it using a tester whether it has a supply... check also the flex.. maybe it has a damage.... check also the keypad crystal ic......
Apr 02, 2011 | Nokia 6500 Slide Cellular Phone
Nokia 6500s keypad not working how to fix it
My Dear Your Phone Keypad IC Fault So Please change Keypad IC
And Keypad Problem will Solved
Nov 09, 2010 | Nokia 6500 Slide Cellular Phone
My Nokia 6500 slide buttons don't work. The only button that does work is the one that shuts down the phone
that the affects of your keypad ic has gone. then you have to change your keypad ic. thanks
Oct 26, 2010 | Nokia 6500 Slide Cellular Phone
Sometime keypad works and sometime dont work
Open the keypad. And clear the bottom of buttons (like coins) with office elastic eraser.
Aug 14, 2010 | Nokia 6500 Slide Cellular Phone
How do i change the housing on my 6500 slide mobile
You need a T5 screwdriver and a new housing... Use an Original housing, copies dont usually fit right... 1, Remove Back cover and Battery. 2, Remove 4 T5 screws at the back of the phone, run your fingernail/opening tool around the housing and it should come away a little, dont pull it apart as there are 2 ribbons one for the Screen the other for the keypad. 3, Turn the phone over and run your fingernail under the keypad. 4, Carefully take the bottom half away with the phones PCB still in the bottom housing, using a flat screwdriver carefully lift off the two Ribbons 5, You can then remove the keypad from the top part of the phone, this is stuck on by double sided tape pull downwards, there are 2 spring loaded pieces on each side. 6, Remove the 4 T5 screws, 2 under where the Keypad was and 2 at the top 7, Again using your fingernail or a opening tool run around the edge and the screen part should come apart, dont damage the ribbon You now have the phone apart take out the bits and change what you like :)
Jun 10, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 2100 keypad suddenly stopped working
Please try to open the pad and clean its contacts. below is the proceedure to open the phone (if it is not under warranty). you two credit cards and a screw driver.
  • Take front faceplate off by inserting card 1 between housing and silver key. As you pull up, take card 2 and slide it on the side of the phone prying the clips off.
  • Unscrew these 6 screws at the edges with the T6 screwdriver and release the 4 clips surrounding the LCD screen.
  • Slip the little black frame off of the LCD screen, and lift the screen. You should now see a screw. Removing this screw removes the back cover.
  • That’s it! Put your new faceplate or housing in and figure out how to put things back by following the directions here in reverse order.
May 28, 2009 | Nokia 2100 Cellular Phone
Nokia 6500 slide keypad problem
there are 2 things maybe possible to solve that problem, it maybe the source of problem is the  KEYPAD board or the FLEX,, you must refer it to the technician and check the malfunction of keypad.,
Mar 29, 2009 | Nokia 6500 Slide Cellular Phone
Cell Phones Logo
822 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
