Question about Nikon D70 Body Only Digital Camera
Top LCD control panel damage
The control panel/top lcd has cracked and is no longer working. Is there a way to replace it or a place where I can buy the replacement part?
  • krland_99 Oct 20, 2008
    I was hoping maybe you could point me in the direction of a parts dealer. I've searched the internet and haven't been able to locate the part.
    Problem Solver:
  • 5 Answers
Both Top LCD and its window (cover) is replaceable.
Posted on Oct 20, 2008
Cracked screen on kocaso ipad
Hi, if no longer under warranty? a replacement screen is only option. Is the main lcd panel cracked also, i.e. bleeding in display when pressed?
There is an outer cover on top of lcd panel known as the digitizer, this part controls the touch movement of screen. If lcd is undamaged a new digitizer can be purchased at reasonable price here.http://www.aliexpress.com/wholesale/wholesale-kocaso-touch-screen.html
Apr 12, 2013 | Kocaso M1050
I have a hisesense 40" lcd lked tv.i grabbed it fron the top and my finger touched the screen.now its has about 12"black uneven spot and in the spot i have rainbow lcolor lines..plus one blue vertica
It sounds like you cracked the screen. If it is cracked, you cannot fix it. Your only options are to replace the screen (BIG $$$) or buy a new set. If you can email me a pic of the TV I can tell you for sure if the screen is cracked. LCD screen are very thin, about as thick as a dime and it doesn't take much to crack them.
info@back2lifeelectronics.com
Nov 25, 2012 | Televison & Video
My tv had a Wii accient. The screen is cracked now just need to replace the screen.
Not possible to buy a tv LCD screen panel as a refurbish parts by any body else.Except buy it from LG tv corporation themselves.The tv LCD screen panel are 90% important to the tv functions and the cost.Replacing the tv LCD screen panel will cost the same as a new tv.Sorry it is time to buy a new tv.The tv with a damages LCD screen or broken LCD screen panel now only can used as a salvages tv for it electronic PCB boards for other tvs to used as spare parts that it.
Aug 26, 2011 | LG 42LC2D 42 in. LCD HDTV
There a multi colored lines across the entire screen how can i fix this? you can see the TV on.. behind these multi colored lines... very faintly.. please advise how this can be fixed.. chris trizano-...
Hello; Not much info given. Are the lines from top to bottom? , and does EVERY line go fully from top and bottom. If the lines don't go FULLY from top to bottom, you have a cracked LCD panel ( cost more than TV sold for ). If they all go fully from top to bottom, It can still be the LCD panel OR the LCD controller board ( much less expensive ) John
Dec 19, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
CRACK INSIDE THE SCREEN MONITOR DOES NOT DISPLAY PRPOERLY .ONLY CRACK IS DISPLAYED WITH MANY COLOURS
There is no way to fix this problem other than replacing the LCD screen. You can find one on ebay.com if you searched with your laptop's make & model, or better disassemble the LCD screen panel to gain access to the LCD screen, & check the LCD screen's part number &use it to search for a replacement on e-bay.com.
Remember to only buy from top sellers on ebay.com.
Dec 12, 2010 | Computers & Internet
I dropped my hp pavillion dv2000 entertainment laptop and now i have a crack on the screen from the side to the top what can i do?
Unless you want to try and find another screen that may have a broken backlight tube so that you can disassemble the screen and recycle the outside pane along with the electronics, then you could go that route. I have disassembled my share of these lcd panels and they are not only difficult to work with but the components are fragile to begin with, the lcd panel is made up of 5 different panels of glass and plastic and have to be placed in the framework in the proper order as well as the electronic board and backlight tube. It is more financialy feasable to simply replace the entire lcd panel. If the laptop was dropped and the panel cracked...there could be other damage that is not apparent but may crop up later, so in that respect it is better off and easier to replace the panel as a whole. I would also replace the lcd inverter while you have it apart....on ebay the lcd panels can be as inexpensive as $75.00 and the inverters are around $15.00. The link below is to the service manual that goes through the steps in performing the repair yourself.
The lcd removal procedure starts on 5.2
http://tim.id.au/laptops/hp/hp%20pavilion%20dv2000.pdf
May 28, 2010 | Computers & Internet
KDL46W4100 no picture small white crack is visible when turned on. Crack got longer and eventually went across entire screen. People have told me the lcd is broken and it's not worth fixing - ie the part...
Yes, thats correct.
If lcd tv screen got hit by some thing then lcd panel got cracked and does show distorted lines or cracks instead of picture and lcd panel have to be replaced that would cost you 70% to 80% of new tv price.
New TV is better option.
Dec 16, 2009 | Televison & Video
Is it possible to get a 46 inch panel for a sharp
If the actual LCD panel is cracked, you don't want to even bother looking for a replacement. It would be either the same cost or more expensive to replace the LCD panel than to buy a brand new one. The other issue is if you are going to attempt to do it yourself, there is a chance that you might inadvertently damage something in the process so you would be out the money you spent on the LCD panel and you would still need to buy a new one. These are called consumer models for a reason. Mass production drops the price of the unit, but replacement parts outside of that mass production sometimes are as expensive if not more expensive than a brand new whole unit and are a lot of time VERY hard to find. LCD's are disposable once the actual panel is damaged.
Nov 06, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Screen cracked on LTV-32w1
The LCD panel is no longer available for these sets. You better off replacing it now.
Sep 10, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
Replacing Cracked Screen LC-46D62U W/ One From LC-46D64U
I'm curious if getting a replacement lcd panel for a 46" TV is not a problem, how difficult is it to replace it yourself. That is remove a cracked one and replace it with a new one.
Jan 03, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Nikon D70 Body Only Digital Camera Logo
154 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
