Question about Refrigerators
We are looking for a way to build ourselves a freezer
  • 61 Answers
You request is vage.. What are you hoping to do with it how big will it be . is it for food . in the home or commercial use ?/
Posted on Oct 20, 2008
Water in refridgerator
Have a look inside fridge compartment (especially the "roof", if it's a top-mount freezer) & see if you can see any ice build-up (look inside vents that allow cold air into fridge from freezer section. Also, if top-mount freezer, look inside the freezer compartment for ice build-up on "floor", inside vents, or on back wall. These symptoms, combined with water dripping from lots of the "roof" of fridge section (in a top-mount freezer model), can mean several different problems, so best to re-post with more info/symptoms included.
If there's no ice build-up (& the dividing area between fridge & freezer sections isn't particularly cold, which otherwise might indicate hidden ice build-up), it can be as simple as a plugged or obstructed drain tube, which is VERY COMMON. Easiest solution for this latter problem is to use a flexible plastic tube (think similar type as attached to aquarium air pumps), stuff it into drain hole, and blow on the other end. Sometimes you have to blow quite hard to clear an obstruction or complete blockage. If you can't clear the drain tube, it's likely a different problem. Again, a re-post with more info/symptoms will help narrow it down.
Sep 17, 2013 | Roper Refrigerators
Sub zero 501 freezer and refrigerator ice builds up on back panel
Possibly the timer that controls the defrost cycle is defective.
Do you get any defrost melt water in the pan below the frig?
Sep 01, 2012 | Sub-Zero Refrigerators
Rsh1dbrs - freezer fine, fridge now emitting loud 'slow fan' noise after opening /closing. just under 2 yrs old - no problems til now.. cleared it out & looks like ice build up at back ? any...
Check for ice build up in the freezer section. Sounds like a defrost problem .You will need to remove the panel in the freezer and look for ice build up, from there you could have 3 or 4 different parts that one or more has failed
Jul 08, 2011 | Refrigerators
My Lg bottom freezer refrigerator, model # LFC21770ST leaks constantly down in the bottom of the freezer and comes out onto the floor. Ice dams build up under the freezer drawer. I take out the ice, but it...
The drain for the auto defrost water is plugged up somewhere.You will need to look at the very back and bottom inside the freezer to see if you can locate it and clean it out.Also you may have to pull the refrig out from the wall and try to get to it from the back.Hope this aleast gets you looking in the right direction.
Jun 29, 2011 | LG Bottom Freezer Refrigerator w/...
Have a side by side fridge (think it's a Hotspot. The fridge part works fine (as long as the freezer is still running). But the Freezer part is no longer working. Was fine one morning and by that...
Look inside back of freezer and see if ice is forming or a layer of frost is building. If yes it is time to manually defrost and examine these parts=> PSS26MSRSS_Freezer_Section
After clicking on that link you will see photo's of your freezer section. In that photo part location's 230 and 240 are 230 Defrost Heater OEM Part Number=> WR51X10055 That part is most likely burned out. Once you defrost manually with a hair drier or a large bucket of hot water set inside the freezer compartment you may need to take care that water does not over fill the condensate
pan below refrigerator by mopping up the water with a dry towel.
Next part I always change is the=> WR50X10028 Defrost Thermostat
These parts are easy to see and change once the rear panel of your freezer is removed. In most cases you will see the defrost Heater blackened and burned out. Removal of the rear freezer panel is very easy and will save you a lot of money to do this yourself. Just remember to unplug power always while working around electricity and you will be fine. Should you have other questions I will be here to answer them for you, Thanks Sea Breeze
Jun 09, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Our Kenmore frig is not cooling at all! The freezer is doing great however. What could be wrong with it and can we fix it ourselves to save money?
For one reason or another the cold air is not getting from the freezer compartment to the refrigerator side.
Possibilities Are There is ice build up in the vent. The vent is stuck closed or set at closed setting(freezer setting to cold) Defrost thermostat in freezer area not defrosting ice to allow air flow. This you can tell once you remove the back panel in the freezer you will see the inside full of ice.
May 26, 2011 | Kenmore Refrigerators
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Freezer
I have a GSL25JFPH BS refrigerator by GE. It made the whirring sound, a repairman came out and told me that the fan motor needed replacing, price of $277. I sent him away, and after a few minutes on the internet, saw on this site that a new circuitboard (part# WR55X10656) should fix it. I found it on ebay for $83, and it took about fifteen minutes to install. No more whirring!!
Oct 31, 2007 | GE GSL25JFPBS Side by Side Refrigerator
RCA D52W26 Screen problem
remove spkr grill and a few screws, unplug connectors,remove entire screen assy and clean....reassemble
Aug 14, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Problem with ice dispenser in side by side refrigerator
Bensmom, the housing that holds the flapper pin probably cracked causing the flapper not to seal. Whirlpool use to have to replace the whole door at one time because the dispenser housing was a non serviceable part. That got too expensive so they came out with a kit to remedy the problem. The kit comes with instructions but you have to be patient and take your time. You want to determine first if this is the actual problem. You can do so by looking up into the dispenser and seeing if the pin retainer is cracked or broken off. I have done a bunch of these and the kit works great. I hate the job though. Part number for the kit is 8201756. I tried to attach a picture of the kit, but I guess the file was too big...Catriver..post back.
Dec 07, 2006 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
