Question about Casio Exilim EXZ75 Digital Camera
Buttons not working.
This is basically the status of my camera..
=> When i turn it on normally, it stays blank for a couple seconds, then it goes to an adjust menu, where no key buttons work.
=> When i plug it into the computer, i can see all of my files and such, so i know that neither the card or the internals connecting to the card are damaged.
=> After i unplugged it from my computer, it went to a recent picture i took, before the camera stopped working, which was a mountainous background, which was why the screen was lit up in the video. The camera screen was doing its normal stuff, such as popping up the battery sign after 5 or so seconds, and it was acting functional, except for the fact that when i hit any buttons it wouldn't respond.
I would appreciate any help anyone can give me.
PS I was thinking there might be a loose cord inside the camera? If so is it user replaceable? Or would you reccomend bringing it into the local BestBuy.
One more question. Do you think Casio would repair these kinds of things free of charge, considering i didn't break it and it seems to be an internal error?
Thanks for the Help
  • 111 Answers
SOURCE: Pop spilled on camera
I think you can consider this is a water damaged item since water has been immersed into the mainboard which cause sensor failure. Camera internal components were very fragile and I suggest you not open it if you really don't know what is inside unless you have opened it once. I have fixed cameras for my friend before but mostly with part failure not water damaged and I believe your is just partial damaged only. Below is some help links to direct you how to fix your own camera: and other easy way is go to google search URL window or Yahoo and type Casio Digital Camera Service Guides, then they will provide you a lot of links where you can get information to fix your camera. I hope this help.
Posted on Apr 10, 2007
  • 47 Answers
SOURCE: lcd monitor screen stays black
Hey i found this site that is great on how to change a LCD for the camera
Posted on Nov 27, 2007
SOURCE: My camera won't turn on/work
Thank you for your help. After reading posts of a similar sounding problem caused by the charger not being able recognize the battery and re-charge it because it had become too slow. It seemed like this was a common cause for the np-20 lithium ion battery for the casio exilim. the solution was to use a 9v battery and connect the - to - and + to + for ten seconds to jump start it. this was very helpful and was sucessful. My charger was able to recognize my battery and was able to charge it.
Once again giving life to my formerly dead camera. Thank you again for all your help.
Posted on Feb 14, 2009
  • 240 Answers
SOURCE: Is there a way to
Normally changing the battery solves this.Make sure you replace it with a good quality new battery and make sure it goes in the right way around as when you get in a flap it often ends up in the wrong way!
Posted on Jun 11, 2009
  • 6831 Answers
SOURCE: My casio EX-S880 had that common lens error where
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Posted on Feb 13, 2011
LCD is blinking on and off and staying off.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link
Dec 09, 2013 | Sanyo Televison & Video
I need some parts for Gerry Crib model no. 9021. Where can I get those?
These assembly instructions are for Evenflo crib model 9021 manufactured in 1999. When you click on the link, click on the image, select "view raw image" and you will be able to use magnifier to zoom in.
(front and back)
(pg 1&2)
(pg 3&4)
(pg 5&6)
May 18, 2009 | Evenflo Jenny Lind Crib
I need screws for the Gerry 9021
SEE IF THIS HELPS GOOD LUCK: These assembly instructions are for Evenflo crib model 9021 manufactured in 1999. When you click on the link, click on the image, select "view raw image" and you will be able to use magnifier to zoom in.
(front and back)
(pg 1&2)
(pg 3&4)
(pg 5&6)
Feb 13, 2009 | Evenflo Jenny Lind Crib
My creative zen v pluse dosent turn on at all dosent charg and... GO HERE. download a service manual or here I've had mine for 10 months, and the battery is dead. I did pry the Zen apart. There's 3 plastic pieces that hold it together. Just wedge a common screwdriver on the lower front piece first. Then remove the upper piece around the viewing screen;
The little monitor is held into position using double face tape. Gently pry it away from the circuit board. DO NOT REMOVE THE RIBBON CABLE. Let it hang by the cable. Then remove the two screws holding the board to back piece. The battery is mounted on the back side with double face tape pry it off and use a soldering iron to remove it from the circuit board. RICHARDM69
Dec 07, 2008 | Creative Labs ZEN V Plus MP3 Player
"insert smart chip?"
its a peice of **** thats what it is, it happened to me and wont fix!!!!
Oct 20, 2008 | AT&T Sony Ericsson W580i Cell Phone -...
Polaroid Problems
If your having problems with your camera, for about 20.00 you can buy the same camera on Ebay.
Mar 05, 2008 | Polaroid OneStep AutoFocus Instant Camera
We need assembley instructions, or schematics
HOPE THIS HELP YOU OUT GOOD LUCK These assembly instructions are for Evenflo crib model 9021 manufactured in 1999. When you click on the link, click on the image, select "view raw image" and you will be able to use magnifier to zoom in.
(front and back)
(pg 1&2)
(pg 3&4)
(pg 5&6)
Jan 01, 2008 | Bassett Mission Crib
Casio Exilim EXZ75 Digital Camera Logo
94 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
