If i turn it on the picture comes on and looks great for about 10 seconds then goes off. If i turn off and back on i get picture and goes out again. Power never goes out is still green. I just trying to find trouble shooting info on it and seems like a long chore. Any ideas let me know thanks.
It is likely that the backlight inverter is failing. This is a very common problem. The inverter is one of the two ciruit boards inside the monitor. If you can still see a very, very faint image on the monitor, then the backlights are not coming on. The inverter is easily replaced by removing the monitor's back cover, then removing the RF shield over the inverter board (on the left side of the monitor's back), and then finally removing the inverter. A replacement part will cost about $60 as of the time of this writing. The new board will plug right into the 3 cables and is mounted with two screws.
One of the backlight converters might be failing. Check the fuses on the converter, or ask a technician to do it for you. Good luck
Thanks Mr. Weather; your instructions made the job easy... got the back off and accessed the inverter...any suggestions as the best place to get a repacement inverter?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
same Problem
yes i have the same problem
va 720 stays on for only 2 seconds
I have a View Sonic VA720, and the power light stays green all the time, and the screen is black. When you try to turn the power button off you get a picture for about 5 seconds and then it goes black again. with the power light staying green.
