Install Xp From Dos
It is Possible to install XP from DOS mode.
    Scholar:
  • 85 Answers
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Posted on Oct 20, 2008
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
I am not able to install Windows XP on Compaq Presario CQ60-104TU
Recommend removing OLD DOS Operating system First. Then Install Windows XP. XP will NOT upgrade older systems unless it's Windows 98 and Fully Updated. However, can NO Longer do because Microsoft does NOT support any versions other than "2000/ME/XP/Vista".
Jun 09, 2009 | Computers & Internet
Installing Windows XP in place of Kylin OS
If you have a copy of MS-Dos should work. The hard drive needs to be reformatted. This should change the File Allocation Table (Fat) and allow you to install Windows XP. Hope this helps.
Nov 17, 2008 | Computers & Internet
Im trying to install win xp on a used computer
Are you useing the windows xp cd?
Enter the xp setup when asked "press any key to start from cd.." (press a key here so you get into the blue windows installer)
And follow the steps, do you get problems there?
Jun 05, 2008 | E-Machines eMachines Desktop PC
MS-Dos prompt in Windows 2000 & Xp
u can just press alt + enter when u r running ms dos prompt in xp or 2000, it will show u full screen and u once again press alt + enter it will back to normal mode when u come out u just type exit from the command prompt
Mar 16, 2008 | Computers & Internet
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
PC is frozen when I press WIN-key
Do you see the Hard Disk Light ON during the time your computer is frozen? If that is the case there maybe an issue with the Hard Disk Controller.
When you installed a new version of Windows XP, did you format your entire Hard disk? (Just to make sure that your computer doesn't have a viral infection?)
Also, is it that the computer freezes when you press Alt+Enter ...or is it like the computer freezes after you press the Windows Key and then Alt+Enter?
Have you tried the Alt+Tab Combination?
Oct 16, 2007 | Compaq Evo D500 PC Desktop
Computers & Internet Logo
256 people viewed this question
David Payne
David Payne
