Question about Cameras
No signal on screen when camera is turned on, batteries OK
    Habit-Forming:
  • 23 Answers
Look for a button on the back or top of the camera (since you didn't mention brand or model) that's labeled DISP or DISPLAY. With the camera turned on, press this button. If nothing happens within 2-3 seconds, try pressing it once more. If that doesn't work, please add a follow-up post in this thread with your camera brand and model.
Good luck.
Posted on Oct 20, 2008
My tv wont work with the remote i can turn on by hand but remote wont do anything it has new batterys and the red light goes on
TV brand?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
LG:
1) Test the remote:
2) If the remote checked out OK, then look at the back of the TV for the "REMOTE INPUT", use a mini-phone plug and insert the plug into the remote input jack in and out a couple times to clean the switch contacts that select between the front IR receiver of the TV or the rear panel IR input jacks.
Oct 30, 2011 | Televison & Video
No signal, only blue lcd-monitor, when playing my footage, yesterday it was ok. also trouble with recording
Did you try resetting the camera by turning it off, taking out the battery and removing any other source of power? Try this first to hard reset the camera.
Does the optical viewfinder function or is it also blue?
Hopefully hard resetting will solve your problem but if not then there may be an electronics fault in your camera.
Jun 24, 2008 | Sony Handycam DCR-TRV900E Mini DV Digital...
Non functioning batteries ok just stopped no liquid involved not dropped
www.remotes.com
LG:
1) Test the remote:
Aug 23, 2011 | Televison & Video
Does not turn on push power button and screen flashes and turns back off
Is you battery have charged? You need to check your Kodak camera battery is well at first. You can change another battery and to see if the before on is ok.(or is there is a good connection between your battery and battery box). If you battery is OK, there maybe some other problem with the camera, maybe you will get a message before if turn off.
Jan 08, 2011 | Kodak Cameras
Remote control won't work. side buttons will work
Batteries are OK and properly inserted?
www.remotes.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 22, 2010 | Philips 32PFL5403D/27 32 in. LCD TV
My nikon cool pix camera is stuck on the print screen.
I would remove the batteries, wait a few minutes, and reinstall the batteries. That should reset your camera
Jul 15, 2010 | Nikon Coolpix S210 Digital Camera
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Feb 15, 2010 | Olympus Evolt E-510 Digital Camera
System error
ok try this pls take out the mem stick b4 going fwd
factory reset the camera
Home Screen>Settings>Main Settings1>Initialize press OK on Control Button and then OK select Initialize All Settings press OK
then pls turn off the camera and take out the battery then move power switch of camera to ON position for 1 minute
after 1 minute move power switch to OFF position and then put the battery back and see everrything is OK
pls let me know with the results
Rate me FIXYA if i fixed ur problem
Feb 06, 2009 | Sony Cybershot DSC-H3 Digital Camera
Using the camera screen (LCD) as a viewfinder
To use the LCD as a viewfinder: Turn the Mode dial to any Still mode. Press the OK button to turn on the camera screen. Frame your subject in the LCD. Press the Shutter button to take a picture. NOTE: Using the camera screen as a viewfinder significantly reduces battery power. Use it sparingly.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Cameras Logo
41 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
