System restore on server 2003
How to install System restore on server 2003.
    Scholar:
  • 85 Answers
Before we begin, you'll need an XP CD. Doesn't matter if it's home or pro. It shouldn't matter if it has a service pack on it, since all the files will be the same source. In testing i used a slipstreamed cd that already had sp1 on it.
In XP, system restore is installed in syssetup.inf under the inf.always section. If you have XP installed, you can open up %windir%\inf\syssetup.inf and search for [Infs.Always], you'll see the section xp looks at for installing system components. You'll notice it has sr.inf, this is the inf for system restore. For server 2003, if you look at syssetup.inf you won't find sr.inf. This doesn't mean system restore won't work in server 2003, it just means they didn't install it.
So first what we're going to need to do is right click on sr.inf and select 'install', to install it on server 2003. If you have xp installed on another computer/partition you can just right click on it. If you don't, then extract \i386\sr.in_ from the XP cd to your desktop, then right click on it and select 'install'. It'll prompt you where the files are, point it to the XP CD. Once done, it'll prompt to restart, say yes.
That was easy, the next part is the tricky part. After restarting you'll get an error saying the service couldn't start. Specifically the error is error 1068. I searched google and found this link -
CODE
http://www.aerdyne.com/Kbase/article_000005.htm.
The error basically means it cannot run under the service it's on. In system restore's case, it runs under the network service. I know this because in services.msc, for path to executable, it says this: C:\WINDOWS\system32\svchost.exe -k netsvcs. This got me thinking so i opened up sr.inf, and found this line:
[SRSvc_delreg]
HKLM,"Software\Microsoft\Windows NT\CurrentVersion\SvcHost","SRGroup"
I opened up regedit, and this registry key didn't exist. So it seems the sr.inf doesn't register system restore to run under the network services group. Using the above registry key as an example, i opened regedit and went to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost
On the right hand side i saw netsvcs. I double clicked on it, but saw SRService no where (SRService is the name for system restore). On a hunch, at the bottom i added SRService, rebooted, and this time got no error on startup. I opened up rstrui.exe, and system restore opened fine. I also had a System restore tab in system properties now too. I was able to make a restore point fine, then restore the computer to it without any problems. So in the above key, you want to double click on netsvcs, and at the bottom of the list, you want to type in SRService (probably case sensitive).
If you're not good with the registry you can save the following as a whatever.reg file and import it, but because it's binary i can't say if it'll work. I recommend manually adding SRService to the netsvcs key.
---copy below to whatever.reg then double click on it -----
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost]
"netsvcs"=hex(7):41,00,70,00,70,00,4d,00,67,00,6d,00,74,00,00,00,41,00,75,00,\
64,00,69,00,6f,00,53,00,72,00,76,00,00,00,42,00,72,00,6f,00,77,00,73,00,65,\
00,72,00,00,00,43,00,72,00,79,00,70,00,74,00,53,00,76,00,63,00,00,00,44,00,\
4d,00,53,00,65,00,72,00,76,00,65,00,72,00,00,00,45,00,76,00,65,00,6e,00,74,\
00,53,00,79,00,73,00,74,00,65,00,6d,00,00,00,48,00,69,00,64,00,53,00,65,00,\
72,00,76,00,00,00,49,00,61,00,73,00,00,00,49,00,70,00,72,00,69,00,70,00,00,\
00,49,00,72,00,6d,00,6f,00,6e,00,00,00,4c,00,61,00,6e,00,6d,00,61,00,6e,00,\
53,00,65,00,72,00,76,00,65,00,72,00,00,00,4c,00,61,00,6e,00,6d,00,61,00,6e,\
00,57,00,6f,00,72,00,6b,00,73,00,74,00,61,00,74,00,69,00,6f,00,6e,00,00,00,\
4d,00,65,00,73,00,73,00,65,00,6e,00,67,00,65,00,72,00,00,00,4e,00,65,00,74,\
00,6d,00,61,00,6e,00,00,00,4e,00,6c,00,61,00,00,00,4e,00,74,00,6d,00,73,00,\
73,00,76,00,63,00,00,00,4e,00,57,00,43,00,57,00,6f,00,72,00,6b,00,73,00,74,\
00,61,00,74,00,69,00,6f,00,6e,00,00,00,4e,00,77,00,73,00,61,00,70,00,61,00,\
67,00,65,00,6e,00,74,00,00,00,52,00,61,00,73,00,61,00,75,00,74,00,6f,00,00,\
00,52,00,61,00,73,00,6d,00,61,00,6e,00,00,00,52,00,65,00,6d,00,6f,00,74,00,\
65,00,61,00,63,00,63,00,65,00,73,00,73,00,00,00,53,00,61,00,63,00,73,00,76,\
00,72,00,00,00,53,00,63,00,68,00,65,00,64,00,75,00,6c,00,65,00,00,00,53,00,\
65,00,63,00,6c,00,6f,00,67,00,6f,00,6e,00,00,00,53,00,45,00,4e,00,53,00,00,\
00,53,00,68,00,61,00,72,00,65,00,64,00,61,00,63,00,63,00,65,00,73,00,73,00,\
00,00,54,00,68,00,65,00,6d,00,65,00,73,00,00,00,54,00,72,00,6b,00,57,00,6b,\
00,73,00,00,00,54,00,72,00,6b,00,53,00,76,00,72,00,00,00,57,00,33,00,32,00,\
54,00,69,00,6d,00,65,00,00,00,57,00,5a,00,43,00,53,00,56,00,43,00,00,00,57,\
00,6d,00,69,00,00,00,57,00,6d,00,64,00,6d,00,50,00,6d,00,53,00,70,00,00,00,\
77,00,69,00,6e,00,6d,00,67,00,6d,00,74,00,00,00,77,00,75,00,61,00,75,00,73,\
00,65,00,72,00,76,00,00,00,42,00,49,00,54,00,53,00,00,00,53,00,68,00,65,00,\
6c,00,6c,00,48,00,57,00,44,00,65,00,74,00,65,00,63,00,74,00,69,00,6f,00,6e,\
00,00,00,68,00,65,00,6c,00,70,00,73,00,76,00,63,00,00,00,75,00,70,00,6c,00,\
6f,00,61,00,64,00,6d,00,67,00,72,00,00,00,57,00,6d,00,64,00,6d,00,50,00,6d,\
00,53,00,4e,00,00,00,53,00,52,00,53,00,65,00,72,00,76,00,69,00,63,00,65,00,\
00,00,00,00
--- copy above --------------------------------------------------------
That's it! Remember to restart both times.
Posted on Oct 20, 2008
Server restarted automatically
Possibly OS problem, try to reinstall your OS...
Aug 26, 2011 | HP Compaq ProLiant ML350 G3 Server
Tip
How to restore the registry in server 2008
Registry is the heart and soul of any operating system. If you have done any edit in registry you should know how to backup windows registry. You can restore Windows 2000, Windows XP, Windows Server 2003, Windows Vista, and Windows Server 2008 by this method. Before restoring backup you should login with administrator and all open application should be close.
Follow these easy steps to backup registry:-
1. Click Start, and then click Run.
2. In the Open box, type "regedt32", and then click ok.
3. On the Registry menu, click Import.
4. In the open inbox, select .reg backup file and click ok.
after restore you can reboot your system.
on Jun 15, 2012 | Microsoft Computers & Internet
Hi i have HP Proliant ml 150 but i cant install server 2003 . how to install windows server 2003
Windows Server 2003 or Windows XP x64? They're the same operating system as I understand it. You must have 64 bit hardware installed on your computer to run a 64bit operating system.
What errors if any are you seeing when you attempt to install this OS?
Feb 16, 2011 | Computers & Internet
I've just started up my Dell Inspiron, and for some reason the operating system looks like an old version of Windows 2003. It should be set up with Windows Vista, I've had this laptop for about 8 months...
Its not making sense. there is no Windows 2003. Unless you're referring to Windows Server 2003 or Microsoft Office 2003? They're not related except Windows Server 2003 is also an Operating System. I suggest to run PC Restore. Just a reminder, PC restore will restore your computer to factory setting. It will delete all data store in the computer. So you need to back up your files first. To run PC Restore, press Ctrl+F11 upon turning on your computer(While you seee the blue Dell Logo). Hope this will help.
Regards,
Melgasbal
Feb 22, 2010 | Dell Inspiron 1545 Notebook
Problem with DG31PR board while loading windows 2003 server.
check HDD and RAM, make sure your HDD new formated
Sep 03, 2009 | Intel DG31PR Motherboard
I recently upgraded a server from server 2000 to server 2003.
I presume you did not do a full system backup of your Server 2000 system/boot drive before upgrading to Server 2003? If you did, just restore your Server 2000 backup. If not, then backup all your application data files and re-install Sever 2000 as if it was a new install. Then re-install your application and restore the data files.
Another possibility is to check with your application vendor and see if they have a version that works with Server 2003.
Feb 27, 2009 | Microsoft Computers & Internet
I have a 2003 exchange server that was hit by a hacker. Now email will not work
My suggestion is to just format the disk (Backup your data!) and reinstall Windows Server 2003.
Or (I don't have much experience with Windown Server 2k3) Maybe you can restore it with system restore?
Nov 26, 2008 | Dell Inspiron 530s Desktop Computer...
Windows server 2003 drivers
If acer or the manufacturer doesn't have them, you can try pcidatabase.com and getting the device ven info from running devmgmt.msc then right-clicking properties, then details.
The info you'll need is PCI\VEN_[Vendor id]%DEV_[device id]
You could try installing the xp drivers, and ignore any warnings. Just be sure windows restore is turned on, to undo any bad drivers. I'm not sure if Windows 2003 has system restore?
Beyond that, you'd be very hard pressed to find any.
Aug 21, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
