Question about Maytag MDG16PR Gas Commercial Dryer
Maytag MDG16PR gas dryer produces only warm temperature
The dryer is not heating up enough to dry the stuff, though it still blows warm air.
    Habit-Forming:
  • 36 Answers
You could have a blockage of lint either in the dryers front bulk head (where the lint screen is) or you could have a blockage somewhere in the vent line. check those and if you have a blockage remove it and that should clear up the problem
Posted on Jan 02, 2009
We have a Maytag Legacy Series gas dryer, that was working fine but just when we went to turn it back on it stopped working.we check the gas and gas is fine the electricity is on so I'm not sure what if...
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Feb 17, 2015 | Maytag Dryers
My maytag Neptune gas dryer won't start
Thermal Fuse
Air Flow and Heat
Warning
GOD IS GOOD !!!!
Oct 05, 2014 | Dryers
Maytag Neptune MDG6700AWW Gas Dryer runs for 2 min then goes to cool down. Why is it shutting down?
Thermal Fuse
Air Flow and Heat
Warning
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 18, 2014 | Maytag Dryers
How do you check the flame sensor on Maytag dryer?
Thermal Fuse
Air Flow and Heat
Warning
Aug 12, 2014 | Dryers
Gas dryers
Thermal Fuse
Air Flow and Heat
Warning
Aug 09, 2014 | Maytag Dryers
Gas dryer not produce high heat
Thermal Fuse
Air Flow and Heat
Warning
May 14, 2014 | Kenmore 62802 Electric Dryer
MAYTAG DRYER FLAMES KICK ON FOR 5 SECONDS THEN CLICKS OFF
Thermal Fuse
Air Flow and Heat
Warning
May 03, 2014 | Frigidaire Electric Dryer
Dryer is running but doesnt seem to be heating it takes a long time to dry and the clothes are not warm when pulled out
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice
Jul 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Clothes do not dry even though unit runs, tumbles, times, but blows out cold air through vent. Maytag de90-3060406
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 23, 2011 | Dryers
2 year old maytag gas dryer blowing warm air
Hi, Is there ant heat at all? Is it possible the dryer heats at first and stops later in the cycle? The first thing to check is the 4" vent going to the outside. Make sure it is cleared of lint and that it is not pinched off at all.
If the vent is ok, you might need to replace the coils on top the gas valve.
I can help you with this. I just want to narrow it down.
Vic
Jul 05, 2009 | Maytag MGD9700S Gas Dryer
Maytag MDG16PR Gas Commercial Dryer Logo
83 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
