Question about Logitech Z-5500 Computer Speakers
No power in Z-5500 logitech speakers
There is no power in the above mentioned speakers system, kindly help
The logitech z 5500 digital is very sensitive to power peaks. One of the most know problems is that the fuse breaks because of these peaks. I´ll show you how to replace the system´s fuse.
First of all, you just need to write down the specification of the system´s fuse. The system´s fuse specifications are printed in the back side of your subwoofer, right next to the subwoofer´s on/off switch. In an european system it says: "T2AH250V (Time Delayed)". If you use another power voltage (120v), it may say something different. Anyway, write it down on a piece of paper and go to an electricity store and ask for a similar fuse (It is very cheap. Not more than 1$)
-The best way to get a similar fuse would be by bringing the broken fuse with yourself to the store-
In the back of your subwoofer, using an screw-driver, un-screw the fuse´s cover and remove the broken fuse. Replace it with the new fuse, attatch it to the cover and screw it back again.
If you turn on your system now, it will probably work fine.
Posted on Feb 10, 2009
I am having the same power cut problems with my logitech z-5500. when i turn it on i always see some flicky black lights and then disapear. can some body help me cause i had this from ebay and i t was working fine then stop working. please i need a solution before i throught it away....
Posted on Nov 06, 2011
How to connect speakers logitech z 5500 to the TV Samsung UN32F5500 32-Inch 1080p 60Hz Slim Smart LED
Hello there!
I have seen manuals of both the systems. You have two options to connect Logitech z5500 speakers to Samsung UN32F5500 TV.
1. With Optical Audio Cable.
2. Stereo Ear Phone Connection.
Simply plug in Green earphone cable of Logitech Speakers to Green Audio out Jack described on Page 7 of the TV manual. If you are using stereo EP you may not experience 5.1sound separation. And it is also mentioned that you should not use other two audio cables of the tri-EP-cable provided with Logitech speakers.
Have a nice day!
Mar 12, 2014 | Audio Players & Recorders
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
Hello Sir, As I wish to buy a home theatre speaker system.And my budget is upto Rs.5500.I have searched for the same in internets,I found two products that are compatible to me.The products are iball...
Both the speakers you have mentioned are multimedia speakers and don't have Dolby Digital, ProLogic or DTS decoders built in. So if your DVD player does not have 5.1 analogue out , only two speakers will work.
Among the two the creative sounds better but like you mentioned the I ball has a remote and higher output on paper !!.
My recommendation is Logitech X-540.Check the link below.
http://reviews.logitech.com/7061/234/logitech-x-540-5-1-speaker-system-reviews/reviews.htm
Mar 17, 2011 | Audio Players & Recorders
I don't have a sound card.but how can i connect logitech Z-5500 speakers to my pc
Since Logitec Z-5500 is a 5.1 Speaker System you need to purchase a Sound Card to be able to connect it with your pc. You can get a Sound card starting with a price tag of 20 Pounds.
Hope this will help you solve your problem Best Regards NextDoorNerd
Jul 28, 2010 | Logitech Z-5500 Computer Speakers
How can I connect my logitech Z 5500 to a sony bravia KDL-32U3000
You can buy a Digital Coax audio cable from any electronic store, this will be a single cable that will connect from your z-5500 to your TV.
Oct 11, 2009 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 DON'T POWER ON. HELP!!!
check its power supply if its working, first.check the outlets(electrical sockets)just to be sure of proper fit.
May 31, 2009 | Logitech Z-5500 Computer Speakers
Logitech z-5500 control pod
http://cgi.ebay.co.uk/Logitech-Z-5500-Control-Pod-FULLY-WORKING-Unit-Panel_W0QQitemZ180332248253QQcmdZViewItemQQptZUK_Computing_DesktopComponents_RL?hash=item180332248253&_trksid=p3286.c0.m14&_trkparms=72%3A1700|66%3A2|65%3A12|39%3A1|240%3A1318
Feb 26, 2009 | Logitech Z-5500 Computer Speakers
Web camera Logitech Quick Cam Sphere AF
Thank you very much, the problem solved yesterday succesfully.
Oct 12, 2008 | Logitech QuickCam Sphere Webcam
Z-5500 speakers
It depends on what audio outs your tv has. Newer TVs may have a SPDIF port on the back for audio out. Look at the connections on the back of your tv (and in some cases if you have connections on the front, check those too.) and see if any say audio out.
Aug 30, 2008 | Logitech Z-5500 Computer Speakers
Logitech 5500 Surround Sound controller
It 's not the fuse!!!! THAT fuse is only for SUB !!! if that fuse was the problem he wont have power at all.THE problem is with control center .I fix my control center changing 2 diodes ,but a friend of mine have exactly the same problem comming from some transistors with is located above that 2 diodes D700,D701(so he says) --- surf check google and you ll see a lot of customers with exactly same porblem AND THIS PROBLEM I THINK IS SOME DESIGN ERRORS THAT AREN'T FIX BY LOGITECH BEFORE SELLING THIS SYSTEM!!!!!!!!!
Jun 30, 2007 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
932 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
