I have an old rear projection 60" Mitsubishi I keep in my basement. Recently I received 3 colored stripes across the tv and no picture. Now the tv will not stay on very long, it just shuts itself off. I was trying to hold onto thsi set a little whie longer. Is this an easy fix?
  • 77 Answers
It sounds like the color guns are messed up. If they have gone bad, then depending on how old the tv it could be pretty pricey if the parts are even available. My reccomendation would be call your local repair guy and get him to come have a look. He will be able to tell you the exact problem and give you a rought estimate.
Posted on Oct 20, 2008
My picture is almost 3-D like and is red, green and yellow.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi VS-60609 60" Rear Projection...
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
Bad color on mitsubishi dlp wd-73732 hdtv
Light Engine Failure.
Mitsubishi extended the warranty on THIS model to 3 years. Check your manufacture date on the back of the TV, , Then call Mitsubishi. They are replacing light engines and/or replacing TVs with newer models without the problem part.
Jul 22, 2009 | Philips 60PP9202 60" Rear Projection...
The Picture on my Mitsubishi vs-60805 "shrank" then disappeared
it isnt worth it, your verticle diflection is out, that board is about 3-4 hundred, and you would probabily need a service center do it(messing with like 30000 volts)and they will probabily charge around 200
Jan 07, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Multi color stripes on 60 inch sony wega, no picture
it sounds like the projection unit went out. if it is still under waranty then i would take back and get it fixed for free. if anything i would contact sony and tell them what is wrong with the tv.
Dec 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Pinkish red screen
Your set doesnt have a color wheel you have 3 CRTs instead. Try turning down the red drive on the red crt circuit board that should help if not check the resistor that is connected to the red drive switch Vasriable resistor(switch) that is probably open if not the crt is probably at fault. If you need more info let me know.
Mar 24, 2008 | Mitsubishi WS-65809 65" Rear Projection...
I have stripes going thru my screen
Any other electronicc components within 3 feet of the set?...accordianman
Feb 15, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi 60 in vs-60707
. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Aug 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
