Question about GE JVM1320 Microwave Oven
Ge microwave jvm1320 light & fan no longer operate
Just replaced a lower light bulb in MW, now neither lights and exhaust fan operate. Control panel indicates that they are working. I didn't unplug unit when I replaced bulb; perhaps something has short out.
  • GE Master
  • 9,047 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 20, 2008
Controls, heating and turntable function normally, but there is an intermittent failure (approx 80 of the time) where the interior light and blower do not function when the microwave is operating .
follow this test and fix it; God bless you
1)
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
2)
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 31, 2013 | Jenn-Air JMV8100A 1000 Watts Microwave...
Under microwave lights stoped working for GE JVM1660SB 005
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 18, 2011 | GE JVM1665DNSS Microwave Oven
The fan, vent, light and clear button no longer
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
May 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Fan and lights don't work.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also find helpful exploded view diagrams and order parts by entering your full model number here.
May 13, 2010 | GE JVM1320 Microwave Oven
BOTH OF THE COOKTOP/NIGHT LIGHT BULBS NEEDED REPLACEMENT. When removing, both bulbs snapped off their base. Used a pair of needle nose pliers to loosen the lamp bases and removed. Replace with two new 40...
NOTE: FixYa's Web site is currently not notifying us when replies to our Clarification Requests are posted.
So please reply back directly to me for more information.
William E. Miller
prototech@usa.net
Sep 26, 2009 | Amana MVH340 Microwave Oven
The lights and fan don't work after replacing the bulb
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
(sample control panel assembly)
Jul 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Night Light on Microwave Oven
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Sep 19, 2008 | GE XL1800 1100 Watts Microwave Oven
GE XL1800 Microwave Problem
First of all, unplug the oven when changing the bulbs, and use good quality bulbs form a home center, as opposed to dollar store or grocery store subs.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Lighting Problem
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Mar 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1320 Microwave Oven Logo
94 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
