Repairing Damaged Winsock2
How to Repairing Damaged Winsock2 show when you try to release and renew the IP address using IPCONFIG...
    Scholar:
  • 85 Answers
1. Boot the computer using the XP CD. You may need to change the   boot order in the system BIOS. Check your system documentation
  for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the
  options below This portion of the Setup program prepares Microsoft
  Windows XP to run on your computer:
  To setup Windows XP now, press ENTER.
  To repair a Windows XP installation using Recovery Console, press R.
  To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup.
  do not choose "To repair a Windows XP installation using the
  Recovery Console, press R", (you do not want to load Recovery
  Console). I repeat, do not choose "To repair a Windows XP
  installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing
  Windows installations.
  5. Select the XP installation you want to repair from the list and
  press R to start the repair. If Repair is not one of the options,
  read this Warning!!
  6. Setup will copy the necessary files to the hard drive and reboot.
  Do not press any key to boot from CD when the message appears.
  Setup will continue as if it were doing a clean install, but your
  applications and settings will remain intact.
  Blaster worm warning: Do not immediately activate over the internet
  when asked, enable the XP firewall
  [ http://support.microsoft.com/?kbid=283673 ]
  before connecting to the internet. You can activate after the
  firewall is enabled. Control Panel - Network Connections. Right click
  the connection you use, Properties, and there is a check box on the
  Advanced [ http://michaelstevenstech.com/xpfirewall1.jpg ] page.
  7. Reapply updates or service packs applied since initial Windows XP
  installation. Please note that a Repair Install from the Original
  install XP CD will remove SP1/SP2 and service packs will need to be
  reapplied.
  Service Pack 2
  http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-
  4F30-8245-9E368D3CDB5A&displaylang=en
  An option I highly recommend is creating a Slipstreamed XP CD with SP2.
  Slipstreaming Windows XP with Service Pack 2 (SP2)
  http://www.winsupersite.com/showcase/windowsxp_sp2_slipstream.asp
  ______________________________________________________________________
  Warning!!
  If the option to Repair Install is not available and you continue
  with the install;you will delete your Windows folder and Documents
  and Settings folder. All applications that place keys in the registry
  will need to be re-installed. You should exit setup if the repair
  option is not available and consider other options.
  Try the link below if the repair option is not available.
  Windows XP Crashed?
  http://www.digitalwebcast.com/2002/03_mar/tutorials/cw_boot_toot.htm
  Here's Help.
  A salvage mission into the depths of Windows XP, explained by a
  non-geek
  by Charlie White
  Related links
  You May Lose Data or Program Settings After Reinstalling, Repairing,
  or Upgrading Windows XP (Q312369)
  http://support.microsoft.com/default.aspx?scid=kb;en-us;Q312369
  System Restore "Restore Points" Are Missing or Deleted (Q301224)
  http://support.microsoft.com/default.aspx?scid=kb;en-us;Q301224
  How to Perform an In-Place Upgrade (Reinstallation) of Windows XP
  (Q315341)
  http://support.microsoft.com/search/preview.aspx?scid=kb;en-us;Q315341
  Warning!! If the Repair Option is not Available
  What should I do? Most important do not ignore the information below!
  If the option to Repair Install is NOT available and you continue
  with the install; you will delete your Windows folder, Documents and
  Settings folders. All Applications that place keys in the registry
  You should exit setup if the repair option is not available and
  consider other options. I have found if the Repair option is not
  available, XP is usually not repairable and will require a Clean
  install.http://michaelstevenstech.com/cleanxpinstall.html
  If you still have the ability to access the Windows XP installation,
  backup all important files not restorable from other sources before
  attempting any recovery console trouble shooting attempts.
  Possible Fix by reconfiguring boot.ini using Recovery Console.
  1.Boot with XP CD or 6 floppy boot disk set.
  2. Press R to load the Recovery Console.
  3. Type bootcfg.
  4. This should fix any boot.ini errors causing setup not to see the
  XP OS install.
  5. Try the repair install.
  One more suggestion from MVP Alex Nichol
  "Reboot, this time taking the immediate R option, and if the CD
  letter is say K: give these commands
  COPY K:\i386\ntldr C:\
  COPY K:\i386\ntdetect.com C:\
  (two other files needed - just in case)
  1. Type: ATTRIB -H -R -S C:\boot.ini DEL C:\boot.ini
  2. Type: BootCfg /Rebuild
  which will get rid of any damaged boot.ini, search the disk for
  systems and make a new one. This might even result in a damaged
  windows reappearing; but gives another chance of getting at the
  repair"
Posted on Oct 20, 2008
  • Yogendra Kumar
    Yogendra Kumar Oct 20, 2008
    The symptoms when Winsock2 is damaged show when you try to release and renew the IP address using IPCONFIG...
    And you get the following error message:
    An error occurred while renewing interface 'Internet': An operation was attempted on something that is not a socket.
    Also Internet Explorer may give the following error message:
    The page cannot be displayed Additionally, you may have no IP address or no Automatic Private IP Addressing (APIPA) address, and you may be receiving IP packets but not sending them.
    There are two easy ways to determine if Winsock2 is damaged:
    From the XP source files, go to the Support / Tools directory
    Winsock Test Method 1
    Run netdiag /test:winsock
    The end should say Winsock test ..... passed
    Winsock Test Method 2
    Run Msinfo32
    Click on the + by Components
    Click on the by Network
    Click on Protocol
    There should be 10 sections if the Winsock2 key is ok
    MSAFD Tcpip [TCP/IP]
    MSAFD Tcpip [UDP/IP]
    RSVP UDP Service Provider
    RSVP TCP Service Provider
    MSAFD NetBIOS [\Device\NetBT_Tcpip...
    If the names are anything different from those in this list, then likely Winsock2 is corrupted and needs to be repaired.
    If you have any 3rd party software installed, the name MSAFD may be changed.
    There should be no fewer than 10 sections.
    To repair Winsock2
    Run Regedit
    Delete the following two registry keys:
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Winsock
    HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Winsock2
    Restart the computer
    Go to Network Connections
    Right click and select Properties
    Click on the Install button
    Select Protocol
    Click on the Add button
    Click on the Have Disk button
    Browse to the \Windows\inf directory
    Click on the Open button
    Click on the OK button
    Highlight Internet Protocol (TCP/IP)
    Reboot
How do I get tcp/ip address from ISP provider (BigPond)
Normally TCP/IP addresses are allocated using DHCP by the provider to the router. The router will have a private address range, which will be given to a local network by its own TCP/IP.
http://support.telstra.com.au/t5/support/ct-p/Support
Feb 13, 2015 | Computers & Internet
Tip
WinXP Tips And Tricks, Winsock 2 repair
An error occurred while renewing interface internet': An operation was attempted on something that is not a socket.
The end should say Winsock test..... passed
Run Msinfo32
Click on Protocol
MSAFD Tcpip [UCP/IP]
If the name are anything different from those in this list, then likely Winsock2 is corrupted and needs to be repaired.
To repair Winsock2
Run Regedit
Right Click and select properties
Select Protocol
Click on the Have Disk butoon
Click on the OK butoon
Reboot
on Dec 27, 2009 | Computers & Internet
What does computer command "ipconf/release" do?
This command will flush the IP address from an active connection. The correct syntax is ipconfig /release *con* which will release all connections. If you just want to see if you can get a new address then use ipconfig /renew
Sep 03, 2014 | Lenovo ThinkCentre Computers & Internet
How to use ipconfig/renew for router
Open a command prompt window
Write the following:
1. ipconfig /release ( to release current IP address)
2. ipconfig /renew ( to renew IP address )
Jun 10, 2014 | Computers & Internet
Reset ip address
If you use DSL or a cable modem you could try (as mentioned above) resetting your IP address. Go to the RUN command, type "command"
There you can type:
/ipconfig
(shows your current IP)
/ipconfig /ALL
(more details such as when the current IP "lease" expires)
/ipconfig /renew
(renews your IP address)
/ipconfig /release
(drops your current IP)
Bell High Speed users need only reset the modem to obtain a new IP. You can check your current IP address from http://www.ip-details.com
IP Details com Find your IP address Information
Jan 14, 2014 | Lexmark E260dn Laser Printer
Dap 1160 Problem access web admin page
connect device directly to your computer using Ethernet cord. try to release and renew IP from the command prompt
IPCONFIG /RELEASE
IPCONFIG /RENEW
IPCONFIG /FLUSHDNS
then perform ipconfig. From there you will be able to get the IP address of the access point that you will need when accessing web admin page
Dec 22, 2012 | D-Link DAP-1160/B ACCESS POINT, WLESS G,...
My acer aspire 5630 will no make the connection to the internet using the wireless. if i hook it up hard wired it works fine. I also tried a USB wireless but it would not make the connection that way...
Try to release and renew the IP address:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically.
Dec 13, 2010 | Acer Aspire 5630 Notebook
I could not check my ip address using cmd prompt. I typed IPCONFIG it results in showing media disconnected. What i have to do for this?
plug in ur network cable. rt click on my network places go to properties there u dbl clik on tcp/ip change to obtain ip address automatically. apply n exit. after 1 min try running the cmd n type ipconfig/all if not found type ipconfig/release then again ipconfig/renew u will get it.
Aug 07, 2010 | Computers & Internet
How to release and renew the IP address in Win Xp.
Go to start
Go to run
type cmd
to renew the IP command is
ipconfig /renew
to releaed the command is
ipconfig /release
May 03, 2010 | HP Pavilion dv6000z Notebook
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
Tips:
Oct 28, 2008 | Gateway Computers & Internet
Computers & Internet Logo
413 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
