Question about Samsung TX-R3079 Television
No stand by light and no power
I tried to turn on my TV tonight and the stand by lite went out and now I cannot turn it on by the main button on the tv or by the remote. I checked the plug and there is power. Is there a lock on it that we might have enabled by pushing the wrong button? (That pushing the wrong button thing has happened before, but I was always able to remedy it)
Thanks for any suggestions or help!
  • jimmyjim3200 Nov 13, 2008
    I have a Samsung LE40A557P2F with the same problem. The power lead and fuse are both fine but the tv has no stand by light. The TV is fairly new, bought on the 24/06/2008.
  • 308 Answers
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
Posted on Jan 18, 2007
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
  • 453 Answers
SOURCE: does not turn on
u have a problem with the power supply , if u open the tv u would see a blow capacitor normaly 1000Uf at 10 v or 2200uf at 10v , this cap is where is the conector for the signal board
Posted on May 01, 2009
CAYPIANAN
  • 227 Answers
SOURCE: Samsung LCD TV LT-P2045U power issues
yes my friend check the capacitors in the power supply. some techs call them pregnant capacitors
open the set carefully and check the power supply.always remember to unplug the set before you do anything.
Posted on May 12, 2009
  • 7 Answers
SOURCE: Samsung LNR408DX/XAA Wont power up
I had the same problem with a 52" Samsung LCD. I found 2 electrolytic caps with bulging tops on the power supply board. (see pic). I looked to be the 5v section but I'm not sure. I got replacement at Fry's for $1.90 each. All is well!
Ahwatukee Al
Posted on Jul 21, 2009
Samsung LC32C350DLD won't power on, red power lite is on but remote and button on tv does not turn it on! Blown power board?
it may be the stand by chip on the main board check that there is volts getting to the standby side of the main board.also check power board for weak capacitors in line.
Sep 21, 2013 | Samsung Televison & Video
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Jun 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
POWER LITE IS ORANGE TV WILL NOT TURN ON
There is a defective electrolytic capacitor (470MF/16V) on the main board that went bad, it will causes intermittent, slow, or not power up, the location number of the cap is not marked on the board, please see the attached photo to locate it.
Dec 16, 2012 | Westinghouse TX-42F430S Television
I heard a loud pop then the tv turned off
First check the COF ic's on the buffer boards. Next check the main mosfets in the power supply.
Nov 13, 2011 | Televison & Video
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Hi
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
The power went out tonight and now the TV wont turn on. When the power went out the TV was off. I have tried reseting the TV several time to no avail. The green timer light just keeps flashing. Any ideas...
Either the capacitors are shot or the high-voltage transformer aka power supply is shot. You can test power from transformer to main board with a voltmeter. you can test the resistance/continuity of any capacitor with a mulit-meter in the ohm position.
Feb 02, 2010 | Televison & Video
Stand by lcd stays amber, no power
i need to register my 47" vizio tv
Jul 15, 2009 | Vizio L32 32 in. LCD HDTV
No power -- TV will not turn on
This could be the power supply baord / Bad Caps/ They will be puffed up..
Or if the inverter board is bad** Inverter board lights the backlights.
Oct 30, 2008 | Vizio L32 32 in. LCD HDTV
Sony wide screen projection tv 46 inch
you might check the power relay and the main power supply or have a tech do it for you.
Jul 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung TX-R3079 Television Logo
66 people viewed this question
Henry  Thomas
Henry Thomas
