Question about Microsoft Windows XP Media Center Edition 2005 for PC
Windows Error Code
I have an HP Notebook with Windows XP Home. I keep getting the following error code MANY times a day, and do not know how to fix it:
The instruction @ "0x000099ba" referenced memory at "0x00000000". The memory could not be written.
The instruction at "0x77c2a573" referenced memory at "0x00000003".the memory could not be "written".
Posted on Nov 03, 2008
  • 4 Answers
Sounds like you have a marginally damages memory stick or two types of mismatched memory.....have you checked this?
Posted on Oct 20, 2008
I get an assert error code c00e701 on my hp 7350 how do I fix it
im not up to speed with this type of error or what its associated with
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
hope it helps
Jun 05, 2012 | Microsoft Windows XP Home Edition
Error Code: 0x80070002
I think The default security provider in Windows XP has been changed loadTOCNode(2, 'workaround'); To reset the default security provider in Windows XP, delete the relevant registry keys in the Windows registry. To do this, follow these steps:
  1. Start the computer. Press the F8 key during startup to start the computer in Safe mode.
  2. Start Registry Editor (Regedt32.exe).
  3. Delete the following registry keys in the Windows registry: HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\Providers HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptography\Providers
  4. Quit Registry Editor.
  5. Restart the computer
Jun 02, 2010 | IBM ThinkPad A21m 2628 Notebook
When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
Let me know, if needed assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 08, 2009 | Microsoft Windows XP Home Edition
Trying to use HP Recovery CDs on notebook. When
This error comes because of bed indexing unit in harddisk.
For that boot your computer with recovery disk then follow the procedure then delete all partition 1 by 1.
Then create new partiton.
then fomrat 1 partition and install windows.
Try this 4 to 5 times then you can success .
Let me know if you need further assistance.
Thanks.
Nov 04, 2009 | Compaq Presario Notebook
Code 646 when trying to update
You need to disable your firewall. If you’re using McAfee Personal Firewall, or Norton Internet Security or another Firewall vendor, see vendor support page for assistance in disabling it (temporarily).
If you’re using the built-in Vista Firewall, keep reading.
- Open the Control Panel and select Security.
-Select Turn Windows Firewall on or off.
- Select Off (not recommended), click Apply and then OK.
- Back at the Windows Update screen, click the Try again button.
-The download(s) and installation should start…
-And this time successfully install. Now make sure to re-enable your Firewall once your PC restarts.
* Though this solution will work for most Vista Update errors.
Oct 24, 2009 | HP Pavilion dv1000 Notebook
Fatal Error
remove the old software first
go to www.hp.com for fresh drivers(get the larger one)
install
try it again
http://tinyurl.com/6qcpgy
Aug 07, 2008 | HP LaserJet 3055 All-In-One Printer
Fatal error installing HP 3055 all in one
Try download he right software for your OS from HP.com, typically software issue. Be sure to choose the right language for your full software solution, get fatal error when trying to install software with wrong language support.
Aug 02, 2008 | HP LaserJet 3050 All-In-One Printer
Power saver error 0x5
Download the hotkey utility from the toshiba web site. I got this errorafter installing service pack 2 for xp. The hotkey utility fixed it.error appeared every time I started windows xp. Go to:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
and go to downloads, select model and download:
Toshiba Hotkey Utility
Install and restart, problem solved. thank you, thank you...
Dec 10, 2007 | Toshiba Satellite A105 Notebook
Microsoft Windows XP Media Center Edition 2005 for PC Logo
426 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
