Question about Emerson AV101 System
Emerson AV101 System no sound
I got this reciver about 2 years ago worked fine for awile but one day i turned it on and the display said SPK OFF and no sound came out i tried every thing from resting it to geting all new spekers and i still can't get it to work any sugession thanks in advance
  • 26 Answers
It could be one of two things.... the first is that the speaker selector is set to OFF. the other thing (also the more expensive one) is that there is a problem with the amp, and you either have a problem with the offset voltage on the output of the amp, or that the idle current in one of the output stages is too high. normally, a protection circuit monitors the output stages for these two faults, and if there's no problem, your speaker relay clicks in within 30 seconds of turning on the power. if there's a problem, the relay never clicks in. so first check your speaker selector. if it's done by "soft switching" (not a physical selector switch, but a microprocessor controlled relay) then you also could have a problem with the processor chip, or with the parameter storage memory (which sometimes uses a backup battery). sometimes the backup battery isn't a battery at all, but a very large (electrically, not physically) capacitor that keeps alive the parameter RAM. if the power is left off for more than 2 or 3 days, the capacitor will lose it's charge, and the stereo "loses it's mind". same thing if it's a dead backup battery. sometimes if the battery is marginal, you lose some settings, but not others or the settings get changed
Posted on Jun 28, 2006
Sound system is not working last two days
you can do a system restore back to the date it was working fine. If it was working fine 2 DAYS ago then restore back to the day before. read this to walk you thru the system restore
http://support.microsoft.com/kb/306084
Feb 22, 2010 | Compaq Presario Notebook
I have lost the sound on my acer3690 series
good day meg2007, if you use microsoft windows xp or vista
1. Check your control panel. or look your display speaker sound in desktop, can you see it, double click spk icon in your desktop, and change volume rate or remove check sign in mute bar.
2. If spk icon is not in place check with this , click your control panel, click system , click hardware configuration , look are you see aknown sign, if yes i thinks you must install your sound driver again.
ok i hope help you , Fix Ya
Sep 26, 2008 | Computers & Internet
Sony kdfe55a 20
2 YEAR IS TIME TO RPLECE LAMP
Mar 30, 2008 | Sony KDF-E55A20 55 in. LCD Television
Surround System Subwoofer Intermitent
have u checked for loosened pieces in the subwoofer case ?
Most probably is the wire that connect on to the speakers membrane, that broke off from the glue it holds it ...
also check the filters ... (the capacitors , see if they are inflated,burned, or blackened, and if so change them ..)
Jan 24, 2008 | Emerson AV101 System
SOUND PROBLEM
Good Morning
If you set the volume up, and there is a problem with audio, I recomend,
1) reconnect your speakers and press well the conector, (green)
2) see if sound came from output connector using a headset.
3) buy new speakers.
depending on the model of your current spk. check one from creative, they have some good Spk. that work fine for years.
Jan 11, 2008 | Audio Players & Recorders
I'm in the same boat... happened once before, then came back to life. Now it's back to a red standby light and no ejecting tray
Mar 04, 2007 | Emerson AV101 System
Display but no sound
so sorry no one got back to you with an answer as we exxperts try our best to get back to everyone in a timley fashion .. Your problem sounds like it could be in the powe supply or the output section of the circuit. If your a handy man the I would leave this to the pros BUT if your a tech then you certainly can get the manual and procede with this repair. Tyy looking up emerson on the WWW or try this # Good Luck 905-940-5089
May 24, 2006 | Emerson AV101 System
Your gonna need a service manual and then you should check the power supply first and then the microprocessor curcuit.Good Luck
Apr 22, 2006 | Emerson AV101 System
176 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
