Question about Motorola Mobility V360 Cellular Phone
Bluetooth my phone says the bluetooth link is always busy
    Sergeant:
  • 226 Answers
Try do a master reset and master clear in the settings menu, if still faulty, u have a hardware problem
Posted on Jan 05, 2010
Licencekey for ultramp3
. Ensure that your willing to consider pairing your phone with your PC in bluetooth mode 2. If so, please proceed 3. Place both your computer and telephone in bluetooth discovery mode 4. Setup up bluetooth simple password such as 12345 5. Accept the incoming connection on both devices and start to transfer your information this way 6. Understand that most cell phones have built in device drivers to allow for easy linking when attempting to connect your phone straight into your PC. 7. When the technological market invented bluetooth, and sim cards, many cell phone carriers NO LONGER place a large importance with direct linking. 8. You may always share an internet connection between your cell phone and your computer by using bluetooth technology. (Very reliable and cost efficient). 9. If you need a bluetooth adapter for your pc, you may always purchase one off the internet for a few dollars. 10.Please advise on how I may continue assisting you so we MAY RESOLVE YOUR PROBLEM THE FIRST TIME AROUND.
Jan 23, 2011 | Nokia 6600
Enter ristriction code
Jan 23, 2011 | Nokia 3110 Cellular Phone
My phone gallery is always busy even i get one Snape it is showing "temporary overload continue" like that what i want to do
it hardware problem.
gallery always busy, and temporary overload after capture picture with camera.
change the bluetooth ic or change the bluetooth module.
if you can do hardware repair. try to reball the bluetooth ic inside the bluetooth module.
if you can't do that, bring your phone to technician.
Sep 23, 2009 | Nokia 6600
Bluetooth
i can just help you with your bluetooth problem.... press the left soft key which is for 'shortcuts' and there is an option for turning off bluetooth... otherwise go to menu - settings - connections - bluetooth - options - manage - setup bluetooth - bluetooth power.
Mar 14, 2009 | Motorola Mobility ROKR E8 Cellular Phone
Phone problems
If you have a bluetooth headset, make sure you switch your headset of completely as it occupies your bluetooth link even if your not currently engaged in a call, then if that doesnt work turn your phone off and on and that should do the trick
Jul 18, 2008 | Motorola Mobility RAZR V3
Bluetooth link busy
Try it with another BT and see if still shows the same.....if it does, then you might need to reset your phone....refer to user manual on how to reset phone. And if it worked fine with another BT device, then you might want to exchange/repair the jawbone....try this first, drain the battery completely from the jawbone, then recharge it and try to connect after charging..
Best of luck....
Jul 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth problem
You must power cycle your phone and shut off the device you are trying to pair and start over.
Mar 07, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Bluetooth link busy
Switch you bluetooth on and then off again.
That Might Work.
Regards,
Sophie x
Feb 12, 2008 | Motorola Mobility RAZR V3
Bluetooth link busy
how can i get my h700 bluetooth to stop saying bluetooth link busy ?
Nov 10, 2007 | Motorola Mobility RAZR V3
My Motorola V3i Buetooth will not connect as is it permanently busy.
try to use the service after removing the memory card and than try, if the same problem presist than the problem is with the BT connector, it will be solved by any local vendor nearby u, and if it works after pluging out the memory card than format the memory card once and than try...... take the bacup of ur data first.
Oct 15, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Motorola Mobility V360 Cellular Phone Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
