Question about JVC AV32F476 32" TV
TCL TV picture too dark
TCL TV model T-68T17 less than 2 years old. The picture is way too dark. I adjusted the "bright.. color.. settings to manufacturers specs, but the picture is still too dark. Would appreciate your input.
Ta.
Keith T ( info @ 15ddc.com )
Try turning the light sensor off
Posted on Oct 28, 2011
  • aaron alexander Sep 30, 2013
    bright -68,contrast-62,sharp-50,backlight-19,color-46,ct off,db off, sabc off
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Screen is too dark
with a flashlight at the back of the set often times there is an adjustment you can make WITHOUT having to open the set!!!
look for a little hole in the back of the plastic cabinet labeled SCREEN then with a flat screwdriver holding only the plastic handle, insert it into the hole and SLOWLY rotate until the screen brightens up until it is watchable.
This is compensating for age in the picture tube. you may get a few day or a few more years! of a much better picture.
If you start seeing some thin lines on the screen then back off you have gone too far. Do this adjustment with the brightness and contrast controls on the menu turned up all the way.
it is also safe to play with the focus adjustment right next to the screen if thing seem a little blurry. you will need two people one to watch from a distance for best picture.
Feb 10, 2009 | GE 31GT660 TV
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Feb 01, 2009 | Hitachi 57F500 57" Rear Projection...
Dark picture
you know it sounds like the same problem i had....
look this is something you can try.... "turn the tv off and unplugg it!!!"...you'll need to take out the lower front part of the tv......(where the speakers are to be exact) on each lower end you will find 2 screws..Be careful it will open to the side and there are many wires, i suggest you mark them to know where to put them back...then right in the middle there will be a black cover with about 5 screws..take them out....and look at the very bottom you'll see a thing with 6 pegs....the top ones are for the screen "DO NOT TOUCH THEM"...the ones on the bottom are for the colors...re adjust them...the left one it's for blue, the middle one it's for green and the last one it's for red...
I had the same problem after i moved....and after i re adjust that the tv looks super...
i hope that helps..:P
Sep 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Dark picture
do you get all three colors? red, blue and green?
Dec 16, 2007 | Panasonic PT-51G44 51" Rear Projection...
Rca home theatre big screen tv
# 1 above you have covergence problems ,there is a service flash from rca to fix your fault,ask your tv shop. fault # 2 above turn off the color and adjust your screen settings for a grey picture,set brightness and contrast to middle settings. # 3 fault read #1 cause if your auto focus will not correct you require service there is a harness connector that looses connection and causes several fualts on the 52" rca's you can repair the fault but if you miss the harness replacement you will do it again.
Dec 01, 2007 | RCA 32F531T 32" TV
JVC AV27320 Screen too dark
Check the lumans circuit. may be jungle IC
Nov 02, 2007 | Samsung HC-P4241W 42" Rear Projection...
Colors are distorted, brightness excessive
You may have a bad Fly Back transformer. The focus and screen(brightness) controls are located on this transformer. Some of the new RCA's have had problems with this transformer. If the screen control opens up the picture may either go dark or light which would cause your problem. Also a bad Picture tube could cause this. It shouldn't since the tv is not very old though. I've seen a few new ones go bad. Stargazer
Jan 29, 2007 | RCA 35V432T 35" TV
RCA F32649
i dont know this exact model, but i can advice you based on a slightly diffrent model. i hope the solution will be valid for your model as well: TV is digital controlled and have to be adjusted via service menu except the external focus and screen on back of (flyback) high voltage transformer. This is one you can try: Need plastic allen or plastic small flat blade screwdriver to fit these. Focus is top, bottom is the screen that set the overall brightness. Before adjusting, go in menu: press menu once, select picture quality, I think number 4, press 2 for "preset..", press 2 again to select normal. Back out by pressing zero repeatedly. It may ask you to save new settings, select yes. If screen is adjusted too bright, picture look lousy (washed out) the blacks will light up (becomes grey, or visible lines) this means you have actual fault that prevents you to get decent pix, that when it is time to take it in for repair.
Feb 11, 2006 | RCA F32649 32" TV
JVC AV32F476 32" TV Logo
827 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
