Service Kit LSUC002
What does the ballast service kit (LSUC0022) you referenced in your solution consist of. Is it a card that is a one-for-one swap, or is it a bunch of components that need to be installed onto a board? I am having the flasking red power light (1X every second) and lamp light (1X every five secs). I replaced the lamp..no luck. From what I've been reading, its sounding alot like the ballast. Any assistance you could provide, will be greatly appreciated.
thanks
Rob
rdmcconkey@gmail.com
SOURCE: Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Posted on Jan 12, 2008
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
SOURCE: Mitsubishi DLP - model #WD62725
fixityrsel is wrong.
1 The "Airflow message"is just a bad connection and very easily solved.Mitsubishi has a service bulletin out and will cover the repair for free. Your set may not even have the defective connectors.
Your set was manufactured in 2004..Call any authorized Mitsubishi
servicer.
Capacitors are very easy to find! Any (105 degree) PC mount 3300uf@ 16VDC will work fine..and not bulge again..Higher Working voltage than the stock 10 VDC is what caused the problem with the caps.
Mouser electronic is one of hundreds of suppliers for those caps
Order online if you know for sure they are bad in your set.
Dan
Posted on Aug 14, 2008
texasdan
  • 60 Answers
SOURCE: Blinking Green light after Capacitor kit replacement WD-62725
I just repaired two Mit WD-62725 sets in the last two weeks.
The first one had bad caps on the power board and the FMT board. The scond one had bad caps on four out of the five boards.
Also, on the FMT board, there was a blown surface-mount fuse.
I advise checking all of the boards for bad caps. If you fine a bad 1000uf cap, replace all of the 1000uf's on the board.
Hop this helps,
Dan
Posted on Sep 06, 2009
Testimonial: "Great comments. Quick to respond!"
ladywinn
  • 5138 Answers
SOURCE: rca lamp replacement, still no picture, power light still blinks.
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
Posted on Dec 30, 2009
My panasonic power ligth blinks green every second for about a minute and then blinks red. I replaced the bub and it still does the same thing. I have no illumination on the screen
There's is ballast kit for this TV I fixed too many of these.
Be very carefull! not to damage a very fragile flat cable when you try pulling the Boards or Chassis. This cable is on the left hand side of the light engine. The ballast kit part# is LSUC0022.
You may wana hire a TV tech if you are not an Electronic technician.
Best of luck
www.aaatvservice.com
Nov 03, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Tip
Lamp vs Ballast
This is to help explain the short lives of Lamps.
WARRANTY: If a lamp fails within the first year replace Lamp and Ballast.
If Lamp explodes do not replace Ballast only lamp, but if lamp didn’t explode replace both.
If you experience more than one Lamp failure within one year of use replace the Ballast.
The Panasonic Brand offers a Ballast repair kit (LSUC0022), it only works about 20% of the time.
I would not recommend this replacement kit. It will get you past the 30-45 day warranty period in most cases but it will not be the proper FIX to the customer’s unit and they will only call you back or (most important) call another Service Center.
I have experienced maybe 100 customers that had other Service Companies come out and only replace the Lamp. When the Lamp and Ballast should have been replaced.
I hope this helps the Customers and the Technicians in their judgment.
If I was redundant I apologize, just trying to help.
Good Day, big IRISH
on Dec 09, 2009 | Televison & Video
Need kit to repair panasonic PT-50LC13 ballast
Check partstore.com to find the kit. The kit part number is LSUC0022.
Oct 15, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Tv will not click for pic to show, bulb good, just blicks green
This TV has a Service Bulletin on it that indicates you should install a Ballast Kit.
Also replace the Lamp with a Panasonic Lamp / No generic.If you just replace the Lamp only, it will burn out fast without the new Ballast Kit installed first. Call a good TV tech and have him check for this problem first.
Jul 31, 2009 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13 won't turn on. Will blink green and make a chirp noise
It is the balister not the lamp. Very common problem that Panasonic will not address. Costs over $600 to repair. file a complaint with consumer affairs please.
http://www.consumeraffairs.com/php/a_report.php
Jul 03, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic pt-50lc13
The ballast probably needs to be repaired. A repair kit #LSUC0022 is available from Panasonic.
Jul 18, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Lamp light (lite the color red)
Chances are its the bad capacitor issue on the power pwb, These symptoms will mimic a bad ballast. You can get a repair kit for the V26 PWB PCB at the following link which contains the replacement capacitors and a CD which identifies the board and capacitor location that needs the capacitors changed and also contains the Service manual on that CD, and the entire kit costt less than just the service manual anywhere else. They have free tech support to help you with the repair as well. Heres the link the kits are listed under the repair kit catagory.
http://servicemanuals.vstore.ca/
Jul 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Where can i buy the ballast repair kit for the PT-50LC13 tv?
try these guys out
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=150273671347&ssPageName=STRK:MEWA:IT&ih=005
Jul 03, 2008 | Panasonic PT-50LCX63 50" Rear Projection...
Ballast problem on PT-40LC12
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Feb 01, 2008 | Panasonic PT-40LC12 40" Rear Projection...
PT 50LC13-50 Panasonic TV
Going through bulbs that quickly would indicate to me a problem with the ballast or smps (switch mode power supply). It's not something you want to just run out and replace (expensive).. Call a reputable shop and tell them what you're experiencing.
I do know that they should check the value of C1330 in ballast circuit. If it is a .22uf, There is an upgrade kit available for it, panasonic p/n# LSUC0022
Nov 05, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Electro Med Services...
