Question about Philips 60P8341 60" Rear Projection Television
Glowing Brightness around light colors and white?
My dad just gave me a Philips 60P8341 60 in. Rear Projection TV.
He said it worked fine at his house,He just upgraded to a LCD TV.
From the move, in the back of the pick up,across town.
I got it all hooked up,but now there is a glowing brightness around all white or light colors.
I suspect dust got moved around on the lenses.
I read in these posts,it may be dirty lenses.
I am pretty mechanically inclined,but have never seen the inside of one of these TV's.
What is the process of opening up the TV,and getting to the lenses and cleaning them.
I read use camara lense cleaner or mild dish soap,and lense cloth.
Pictures would be helpfull too.
4 Suggested Answers
SOURCE: I have a philips tv, model # 9p5034 c103
you need a repairman to reset the prizum
Posted on Jan 07, 2008
SOURCE: Projection Tv picture
have you checked the cooling fluid in the crts.probably dirty
Posted on Jan 20, 2008
Ecollier2012
  • 3459 Answers
SOURCE: blurry edges, white objects too bright, glowing
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 07, 2009
Colors on my TV seem to be washed out. Convergence is adjusted OK, brightness/color/tint settings don't seem to make a difference. I seem to have bright halos around all light colored images.
The fluid in the picture tubes needs replaced. It is a job for a professional. It usually costs about $250.00 for the job. You might say it's like giving your set an oil change.
Apr 09, 2011 | Philips 50P8341 50" Rear Projection...
The tv seems to be glowing, especially all the bright colors. Have adjusted brightness, sharpness, color and so forth and nothing seems to fix it. What can I do?
Your problem is the fluid in the 3 picture tubes needs to be replaced. All the older projection sets used this type of cooling for the tubes. After time and usage the fluid becomes contaminated and starts to turn brown and light cannot get through the crud and therefore you wind up with a dull picture. I recommend having a service company do this procedure. It is very detrimental to the printed circuit boards and components if you would spill and on them. Most shops charge around $250.00 to replace the fluid.
Jan 04, 2011 | Philips 60PP9202 60" Rear Projection...
My tv I have it on the highist you can go on the brightness what could be wrong.
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 16, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have a philips HD rear projection TV 60 in. inside there are six adjustment knobs. Three are color the other three are for brightness contrast and hue. Which is which Left to right
If yours is a rear projection TV the adjustment knobs on the focus block inside are screen (red, green, blue) and focus (red, green, blue). The ones you are referring to as color are the screen controls and they adjust the intensity of the color from each tube. The other set adjust the focus of each color. They are also not intended to be adjusted by the user. Unless major components have been changed these controls should not need adjustment. That is why they are inside the TV.
Dec 05, 2009 | Philips 60PP9352 60" Rear Projection...
Phillips 43" T.V sound is fine Picture is Faded? Still visible but very light and faded..How do I fix
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 06, 2009 | Philips 43PP9202 43" Rear Projection...
The words blare green around them.
revise la convergencia de su tv iy los anillos del cañon
Aug 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
Jan 20, 2008 | Philips Magnavox 51MP392H Rear Projection...
Brightness Problem
If it is a glow around the edges, it could be one of two problems. The Picture tubes could be getting soft or weak, or there is a bad capacitor in the screen drive circuit or in the sweep power supply. If you have a service manual and a multimeter, you should be able to locate a bad capacitor with an ESR type capacitor checker. If you do not have any knowledge on solid state repairs, please call in a pro to assist you in this repair. Good Luck.
Mar 14, 2007 | Philips 60P8341 60" Rear Projection...
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
