Question about Acer Computers & Internet
I cant get the keyboard letters to work that have the blue numbers on them without pushing the fn blue button in the bottom row at the same time
  • 903 Answers
That is how the function keys on some keyboards work. Other keyboards have a key that says Fmode. When this is pressed then the blue keys will work all the time. Other than that the Fn key needs to be pressed at the same time as the function key you are using.
Posted on Oct 23, 2008
Irei have a acer aspire 5050 laptop and the number one key is not working, but there is a number one in blue on the j key, how do i use this
The buttons with the blue items are accessed by pressing and holding the Fn (Function) or Special key...it will be in the bottom row of the keyboard and have writing in the same blue color. If you hold this button the keys with the blue writing will be activated.
Jun 18, 2011 | Computers & Internet
My laptop is only typing the numbers that appear on the letter keys. For example when I hit the letter J, it types a number 1. When I hit the letter k key, it types a 2, etc. How do I get it to go back...
Usually you have to hold the "Fn" key to get to these. Look for a "NumLock" key to turn this off. You may need to use the "Fn" key to select numlock.
Mar 10, 2011 | Computers & Internet
You state to hold the fn, and hit the power button.....OK, whats the ( fn ) key ?
The Fn key is a key found usually on the keyboards of portable computers (laptops, netbooks etc) and sometimes on desktop type keyboards.
It is a key usually marked with a blue coloured "Fn" and is located somewhere on the bottom left row of keys.
The Fn key is used in combination with other keys that have (usually) blue letters or icons on them to activate the special functions (Fn) on these keys.
For example, on the laptop I'm writing this on; If I press F5 the computer would perform the action my software has normally assigned to F5. If however I press the Fn button and F5, the computers internal function for decreasing screen brightness is invoked.
Different computer makes have different assignment to their keyboard Fn so you can't generally say press Fn+F5 to decrease screen brightness, it might be assigned to something else, volume or sleep-mode or even nothing. The "blue" text or icon will give an indication of what it will do.
Hope this helps explain the Fn key ;)
Feb 01, 2011 | Dell Inspiron 6400 Notebook
Can`t figure out keyboard on acer aspire one, blue numbers and letters etc Karl
blue number etc are functions that are connected to the blue fn button in the left hand corner.
press and hold the blue fn button and at the some time one of the other buttons.
eg volume + or - for volume up and down or the moon shape for hibernate, or the sun to change the screen brightness,antenna button to switch on and of your bluetoot or wifi, or the screen button to switch on and off your external monitor port on the back etc. the blue number are your numeric keypad like on a normal keyboard this can be used in the same way by holding the blue fn button down at the same time.
I hope this was helpful
Dec 12, 2010 | Acer NSK8458AN Keyboard
Can you tell me how to switch my laptop keyboard
Hold function (Fn) key down and press the key on the top row that has a sign (picture) showing a padlock insde a square. (Num lock key) Normally "scroll" key
Apr 02, 2010 | Gateway 2520915 Keyboard
Keyboard Produces Numbers Instead of Letters when Num Lock key is on. For example here is what I get when pressing the keys from Q all the way over to the \ key on that row of keys when I have the caps off...
I have the same problem. Click the Windows start button. At the bottom is a Windows Serach box. Type 'keyboard'. A virtual keyboard appears. Click the NumLock key on the Virtual Keyboard. This should override the issue you are having and your keyboard and keys should now work. Otherwise reboot!
Feb 16, 2010 | HP Pavilion DV9910US Notebook
Fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
Mar 10, 2009 | Dell Inspiron 1501 Notebook
The letters on my keypad some will only type numbers serial #N326171062571 model MX7625 if i hold down the bottom left key of the pad that displays Fn in blue letters then the letters work instead of...
1. Open the on screen keyboard by going to "control panel" then "Ease of Access Center" then click on "onscreen keyboard".
2. click and hold down the "Fn" key on the physical keyboard and then hit F11 on the onscreen Keyboard.
3. All Fixed. Spread the word.
Oct 16, 2008 | Gateway Computers & Internet
Wireless keyboard and mouse
on your keypad there is a button ' fn' (normaly on near the windows key, blue in colour) which when pressed along with another one on the keypad (somewhere in the top row of the keypad) activates this function, what you have to do is a press these two key again simultaneously to de-activate this function. the second button or key will most likely be paired with one of the f_ keys
Sep 08, 2008 | Acer Aspire 5100 Notebook
Only half my letter's work!
you are correct, the number lock is on, use the blue "FN" key and in blue under the "ins" key you should see "Num LK" push the two together and presto, normal keyboard
Feb 28, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
