Question about Bosch 2400ES LP AquaStar 6.4 GPM Indoor Tankless Liquid Propane Water Heate
Rinnai infinity hot water service, goes hot and cold...not fun in the shower!
Hi I have moved into a rental property and it has one of the rinnai hot water things now I have a control in the kitchen and one in the bathroom, i set the water to 38 and jump in the shower it is nice and toasty then after a minute or so it goes cold then warms up again then goes cold again constantly until I give up and get out totally annoyed. Neither the kitchen or the shower holds a consistent heat, thought I would see if anyone knew anything about these things as the estate agent seems to have no idea at all and I really want a nice hot shower! Thanks heaps!
    New Friend:
  • 4 Answers
We had the same problem - the hot water would only be hot for 3 -5 minutes and shut off, then we had to turn the water off, wait a few minutes, and do it again. VERY FRUSTRATING.
Solution: The Rinnai serviceman showed me the heat-exchanger blower/fan: It was clogged with dust and moths.
Another clue: Our Rinnai was extremely noisy when the heat came on. After the fan was cleaned and replaced, it is nearly silent.
If you are reasonably machanically inclined:
TURN THE BREAKER / POWER OFF to the unit.
The blower-fan is located in the lower central area of the unit (at least on our unit). If you draw imaginary north-south, east-west lines through the center of the unit, the fan is in the lower-left quadrant. There is a spring clamp securing the black rubber accordian-like tube to the fan. There are two screws that secure the fan to the unit. there are two plugs that connect to the fan, as well as a third air-flow sensor that should be removed. then you can look at the fan unit, as well as the grill on the underside of the heat-exchanger that should be cleaned.
My thought was to go out and get a simple bug-screen, and place it over the air-input outlet vent going outside, but the repair guy said that although it may sound good, if that screen ever gets clogged, or reduces airflow to the Rinnai, then the unit will work harder, or even shut off, giving the same problem,
Posted on May 07, 2010
  • james krans Feb 12, 2013
    that fixed my problem, followed your directions and cleaned out my fan. thank you jim
  • 104 Answers
Hightemp needs set and mix valve needs reset- it is adjustable- find book
Posted on Nov 02, 2008
My water temp keeps going up and down in the shower
Posted on Jan 19, 2010
My rinnai infinity water system is not firing up
Posted on Nov 16, 2009
Go to the controller, if you can find book go to the page that shows the controller and check the water flow comming thru the water heater, if waterflow is falling below .06water heater is shuting down. Your water pressure may be to low.
Posted on Jan 13, 2009
    New Friend:
We had the same issues. Couldn't even run a bath.
We found that the dip switchs weren't set correctly for our ELEVATION during install.
We have a Rinnai r75lsi. Refer to user manual page 34 for correct switches per elevation levels.
We changed ours to our correct elevation and have been running consistent hot water since. Hope this helps.
Posted on Apr 05, 2013
SOURCE:
No hot water from kitchen tap
The hot side of the faucet is most likely plugged with something that came up thru the water system. The average thankless waterheater requires at least 1/2 to 3/4 gpm flow rate for the unit to sense flow and turn on. If there is not enough flow it will not fire and heat the water. Not sure about this particular unit but a few require at least one full gallon per minute flow. So chances are that if you fix the faucet, you fix the hot water issue at the same time
Jan 09, 2014 | Rinnai Water Heaters
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
Temperature with my on demand water heater is inconsistent
have a plumber check the installation as it appears that there is a temp control mixer in the kitchen line that should be in the bathroom line
Many states and countries now have made it mandatory the full uncontrolled hot water cannot be used in a bath, shower, wash basin but has to limited to a max temp of 70 C to prevent burns to the skin
May 29, 2017 | Bosch & Tankless LP Hot Water Heater
The rinnai 20 Infinity is perfect but have recently noted a problem. I found the basin hot water tap in the bathroom begin dripping only when the kitchen hot water tap is turned on. I don't know how...
Some taps are designed to release excess pressure but it could just be a dodgy tap washer that leaks when the pressure of hot water in pipe work builds. Change the tap washer in your tap, see if it fixes it, if not it's just the design.
Jul 02, 2011 | Water Heaters
Have a Rannai R75LS and getting hot water everywhere except my sink in the bathroom. System doesn't come on with only bathroom sink running.
I think these have a water pressure s/w or water movement s/w id replace the aerator 1st to a non water saver one or if possible remove water flow reducer looks like a metal washer .. if this not help you may need to replace the pressure s/w...in tank..
May 01, 2011 | Rinnai Water Heaters
My kids just bought an older home w/a rinnai continuum nc-45-4us. right now their house phone isn't installed, so they can't phone, but they can't turn on hot water. any suggestions
Run through the basic checks
  • Power lead from the heater plugged in a socket turned on.
  • Gas on to house
  • All valves below heater in on position.
  • If they have controllers in the house turn on (key pads marked with Rinnai logo in kitchen or bathrooms usually)
There is a turbine that spins in the heater when a hot tap is run. If the heater has been sat for some time not operating the turbine might have stuck. Run the hot tap and keep it running, using a hammer give the centre pipe connection under the heater a firm hit a few times(not too hard). This might unstick the turbine.
Sep 21, 2010 | Rinnai Digital Remote Water Heater Control...
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
Running out of hot water with Vulcan Freeloader 300
hi i need help with mi Vulcan 300 hot water main gas pressure...
our kitchen tap got broken and we turn off our main water pressure in front off our house and now our hot water gas not working ....please help
thank you ...
Sep 24, 2009 | Water Heaters
Hot water tap only warm water in bathroom but hot in kitchen
Usually when you are having a problem at only one fixture, and not any others it is a sign that you have a faulty fixture. Hope this helps.
Jul 16, 2009 | Stiebel Eltron CK20E Electric Tankless...
I need the manual for a Rinnai Infinity 26 hot water system
you can get it off the rinnai web site they have a spot on there to get the internet manuel,, but from what you are saying you may need to adjust the thermostat, or the temp, remember even though you will have endless hot water it still takes the smae amount of timed for the hot water to get to your faucet,, not only that make sure your shower heads aren't holding back to much water pressure, if you don't have enough water going thru the unit it will not stay lit, if will come on and go off, judt to dstisfy the unit,, make sure the filter is clear, on the cold side there is a cap screw if you take it off there is a screen in side you just pull it out and clean it and reinstal it,,
Jun 25, 2009 | Rinnai Digital Remote Water Heater Control...
Bosch 2400ES LP AquaStar 6.4 GPM Indoor Tankless Liquid Propane Water Heate Logo
5,619 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Sheldon Dedek
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
