Question about Cannon Office Equipment & Supplies
My cannon iP 2000 keeps that waste ink well is full how do I repair this
  • 628 Answers
No repair is available. There is a little tray under where the cartridges rest and when the printer does a cleaning cycle, it squirts some ink into it. Eventually, the ink builds up and when the tray is full, it's time to change printers. Here is what Canon says:
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Try this link on how to reset the ink counter: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=ModelFeaturesTabAct&fcategoryid=257&modelid=10237#SupportDetailAct
Posted on Oct 20, 2008
The wast ink absorber is almost full
the waste ink absorber is a small unit inside the printer where the waste ink goes in. it is a common problem in cannon printer. the ink absorber cannot be replaced mate so when it says full, buy a new printer because its not worth repairing it.
Jan 06, 2011 | Canon PIXMA iP90 Mobile Printer
My Cannon ip pixma 2000 is saying that the waste ink absorber is almost full how can i solve this
The waste ink absorber is actually a pad/sponge that absorbs left over ink spray. There's really no precise way to measure the amount of ink these pads hold so when the message first appears, "waste ink absorber is almost full" it's just an estimate.
The workaround for the message is as follows:
Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Using the above procedure should clear the message and your printer should function normally afterward. Best of luck and thanks for using Fixya!
Greg
Nov 08, 2009 | Canon PIXMA iP2000 InkJet Printer
Waste ink nearly full LCD ERRoR on Cannon multipass F60 printer
HiHello try ths
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 17, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Cannon ip90 waste ink tank is full
These is all that u need to do:
4 step to Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
There's a lot of methods and choice on how to reset it and this is all my best to share to you.
If i am helpful please rate me.
Thank you.
Yboyandrei
Aug 15, 2009 | Canon PIXMA iP90 InkJet Printer
Hi, I have a Canon PIXMA iP 1600 printer. Recently, I started to get a message that says: The waste ink absorber is almost full. Press the printer's RESUME button to restart ...
I have a Cannon PIXMA ip 1600 printer. Recently, I am getting a message that says: The waste ink absorver is almost full. Press the printer's resume button to restart printing. What is this ? How to solve this problem ?
Jun 15, 2009 | Office Equipment & Supplies
My Cannon IP 1600 waste ink absorber is full. can you help me?
If when the head is moved to the position for changing carts, I think on the right you may find trays under where the head is parked, normally. Sponge out with cotton buds some of the ink and run a resetter for this machine (Google resetter for Canon ip1600) hope you find it
May 07, 2009 | Office Equipment & Supplies
Cannon
CAN SOMEONE ADVISE ME WHERE TO FIND THE INK ABSORBOR SO I CAN CLEAN IT
Sep 16, 2008 | Canon PIXMA iP1600 Printer
Waste ink absorber on canon iP 1600
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Apr 01, 2008 | Office Equipment & Supplies
187 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
