Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
Not cooling the cooling fan is not working to keef the coils cool. I can spin the fan several time by hand and eventually it starts working for awhile. sometimes it makes a humming noise and spins real slow.
    Problem Solver:
I usually got to solved my problem at this Fixya site,
first of all, I wanna say thank you guyes..
Now I can help sombody got problems..
Ok, the fan usually working 7 to 10 years somtimes 5 years,but you can use it more years,
here is the way, absolutely power off and take it fan out from the board, and take back cover off by small watch driver, its hard to take it out?, spray WD40 back side and front fan side shaft and wait 10 min, spin the fan by ur hand, it might be better swing..
next step is, open back cover, and take out sponge(?) and spray WD40 and try to spin the fan by your hand, its being better moving, and then give the GREASE oil( white or gray grease doesn't matter) harmful the motor back side, you can't open back motor inside, mechanic only do, and then cover it back test it...
before put it back. put power in, spin by your hand more, its be much better..
after that you can use this motor or fan more than 3 to 5years..
Posted on Nov 02, 2011
Disconnect power ...remove lower back panel ...... remove fan and replace.... used appliance shops are a good place for free or cheap fans
I have done this many times on my rental properties
ed
Posted on Oct 20, 2008
I have a airwell GC-30RCC when put on heat the fan on the indoor unit wont kick in it works fine on cooling and plain fan mode but not on heat mode the red fan light is on too
How do you get it to kick in ?.Fid you spin it by hand ,if that's what you did and fan runs then you have a bad capicator. If fan runs fine in cooling and not in heat then you have a bad board
Jun 01, 2017 | Heating & Cooling
1989 ford f 150 i been driving and the engine stop fuel have don't start
could be fuel pump,check for fuel see if fuel pump supplying fuel and you are getting spark.make sure ignition timing is correct and the idle speed setting correct check the under hood emissions information label.also check engine make sure engine not over heating check cooling fan clutch see if cooling fan clutch is okay by turning it by hand if engine is hot cooling fan should have resistance if engine is hot, if cooling fan feel loose no resistance the fan clutch is bad.
Feb 06, 2012 | Ford F-150 Cars & Trucks
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
We have a True TS-49F freezer that the interior fan have stopped working. Holding the door switch does not activate them. Unit is out of warranty.
Most all commercial freezers like yours have, what is called, a fan delay. It is located in the evaporator case and is usually attached on or very close to the actual cooling coil. It may also be a combination switch known as a defrost terminator/ fan delay. It's purpose is to keep from circulating warm air. If the cooling coil does not reach a preset temp, the fans do not come one. Another thing is that the fan motor may just be bad. If you have more than one fan, then chances are that it's going to be the fan delay. I would start there to see that either the fan delay switch is bad or there is a reason that the coil is not getting cold enough to activate the switch.
Nov 09, 2010 | True 49 cu. ft. / 1388 liter Commercial...
I have a dell xps 1210 the cooling fan stopped working I replaced it with a new one and it still won't work
The motherboard may have several 3-pin connectors, for installing fans in different places. Connect the cooling-fan to one of those "alternate" connectors, and start-up your computer, to see if the fan spins.
Try a different power-supply.
Try both the "old" and "new" cooling-fans in a different motherboard, to see if they spin at all.
Oct 23, 2010 | Dell (6F858) Cooling Fan
Hi, Our refrigerator has stopped cooling and I desperately need to try to fix it myself. Lights still come on. Fan or something is still running but the freezer still works so I thought maybe that's what...
There is likely a problem with the defrost circuit or cold air circulating fan (but could be a low freon charge or other problem). The freezer compartment has the cooling coil with defrost heater and a fan that pulls cold air from the freezer and blows it into the fresh food compartment; based on the setting of the thermostat in the fresh food compartment.
When the defrost heater fails, the area that the cooling coil is located in eventually turns into a solid block of frost and ice. It becomes impossible for air to be drawn across the cold coil, cooled and blown into the fresh food compartment. The result is a rising temperature in the fresh food compartment - and eventually in the freezer section, too. Since the fresh food compartment contains the thermostat and the temperature never gets low enough to satisfy it - the compressor runs non-stop. That is, until the defrost timer kicks in to shut it off for 20 minutes or so.
The first thing to do is to manually defrost the freezer by accessing the cooling coil after emptying the contents of the freezer. This can be a pain in the neck to remove racks, shelves, ice maker, etc. to get to the back wall of the freezer, behind which the cooling coil is found. If you expose the cooling coil and it is encased in frost and ice it is a problem with the defrost circuit. If it is not - the fan is suspect. If the fan spins, check for a blocked path between the fan and the fresh food compartment. Defrost by placing a heat source in the freezer or directing the output of a blow dryer at the coil. If you're unable to access the cooling coil, you can simply empty the freezer and defrost it with a heat source. it will take longer to melt all the frost and ice, but it will work.
If it is a defrost circuit problem, you'll need to check voltages and continuity on the defrost terminator & timer and defrost heating element, fans, etc. after completely thawing the ice & frost.
This job isn't a good first time DIY job due to the danger of freezing skin, etc. due to possible exposure to freon in the system and the tight spaces you'll be working in with live voltages. You might want to call a pro after you've defrosted or put up another fixya request if you decide to dig in on your own and need specific help with procedures, locating parts, wiring diagrams, etc.
I hope this was a good starting point to help you decide whether to go forward or not on your own. Good luck!
Oct 07, 2010 | Kenmore Refrigerators
I have 2003 grand cherokee with 140000 miles that overheats at idle. as soon as i start moving again, the temp goes back to normal.
You have two fan's on your truck, 1 is a fan clutch runs with the drive belt, 2 elec fan motor, with test light and engine running at normal temp, just a little bit above 1/2 way on your temp gauge check voltage at elec. cooling fan harness if you have voltage at one of the two wire's and fan don't turn on, bad cooling fan motor, on the fan clutch after you check voltage at elec. fan motor turn engine off, with your hand spin drive belt fan if it spin's freely bad fan clutch, replace it.Also check cooling level.Hope this was very helpful
Jan 21, 2010 | 2006 Jeep Commander
Refrgerator is not cooling
Hi there
I have some stuff for you to read hope this helps you.
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Evaporator coils Condenser Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt. Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem Thank you for writing to fix ya.
Best Regards Richard
Dec 27, 2009 | Refrigerators
General Electric Refrigerator
Check the connection of the electrical harness to the fan motor. If it is fully connected and the motor still does not run replace the fan motor. The fan MUST operate at the same time as the compressor to properly cool the system. Spin the fan blade by hand with he power off. If it turns with any resistance the bearings are dry and in most cases the motor is replaced.
Jun 07, 2008 | GE Refrigerators
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
95 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
