Question about Dryers
Kenmore Dryer -Very little heat
I'm having to use the dryer for about 1hr. 20mins. or so, to dry a medium sized load. Element is fine, and back of dryer (inside) is hot briefly. Any solutions?
I didn't get a manual when I got the dryer, and have had too many arguements with Sears, trying to explain that I didn't get one and just wanted one in the event that I need to fix anything.
Model #110.C6682500
  • FixitGal1 Oct 20, 2008
    Tried this this morning, with dryer pulled out about two feet from wall. Venting to outside strong and checked hose for any debris, etc. No difference. Thanks for the suggestion; any other thoughts aside from replacing the thing?
  • katnchris Nov 07, 2008
    I have a whirlpool gas dryer that is approx. 6 years old.  It hasn't been heating well. It starts out hot and then cools down like it is only air drying.  Repairman cleaned everything out in the dryer itself but suspected that it was the vent.
    We cleaned a ton of stuff out of the long, angled vent, but the dryer is still having the same problem.  Any suggestions?  If it's a big, expensive thing is it worth repairing of replacing?  Already spent $100 for the initial housecall/diagnosis.
    Genius:
  • 1,028 Answers
Remove hose from rear of dryer ..try load with hose off if dryes ok suspect vent hose plugged either at rear when dryer pushed back or between inside and outside exhaust
Posted on Oct 20, 2008
1995 Kenmore Dryer heating issues
Sounds like a Heating element. Most towns have a do it you self appliance repair store. Contact them to price the part. Have you tryed vacuming th ling from the inside of the unit. Sometimes they get loaded with lint and does not heat efficiently. Hope this Helps.
Jun 21, 2013 | Dryers
Dryer heats up, but does not dry clothes. Vent is clean
As you can see, your heating element has 5 heating coils. If one or more of these coils have opened you dryer will still work and heat but not at well as it would if all coils worked together. You can check each coil with an ohm meter to verify if one or more is open.
Jan 01, 2012 | Kenmore 64742 Electric Dryer
Hello, I have Kenmosre 90 series dryer. Did a load ealier today, and it was fine. Went back to put another load in and realised NO heat was on, absolutley no heat in the dryer, the air inside is room...
you may need a heating element. You can go to your locale appliance store and buy the element & install it yourself . Just make sure you take All your dryer info, (etc; the dryer model, make, yr & the serial # ) this info is easy to find, its located inside the dryer door. Just call around your locale area and ask them how much it is for the heating element, for your dryer. It should be rather cheap compared to the cost of Kenmore appliance company coming out to fix it for you. The heating element is rather easy to install. I have installed a few in my own dryers and in my hot water heater.
Thank you.
Sincerely,
cat2868
Jan 28, 2011 | Kenmore 62802 Electric Dryer
Kenmore 110 60942990 dryer works but takes 3 hours to dry a load.
Venting. When elements or thermostats burn out it is almost always caused by venting restrictions. Vent is plugged with lint, smashed(usually from the dryer being pushed back to far) vent run is too long, or nylon stocking on vent outlet. Also check to see if you can pour water through your lint screen. Sometimes fabric softener builds up on the screen and restricts the air flow. Scrub your lint screen to get this build up off. Good Luck, Appliance Specialists
Dec 16, 2009 | Kenmore 62802 Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
KENMORE DRYERS
It could be a malfunction heating element, thermostat or both. In most of the cases it's the heating element. Check with a multi-meter for 115/220V on the heater element tags. In case you get this voltage there, you should replace the heating element. In case you can't read the 115/220V on the heater tags: - Check thermostat's for continuity (you should read a low resistance). In case you can't get any measurement. You should replace the thermostat. Good luck!
Aug 06, 2007 | Zanussi FJS1225W Front Load Washer
Frigidaire Dryer takes too long to dry.
First thing I would do is to take the drum out of the dryer and make sure the back is not all clogged up with lint. That is a very common problem with Frigdaire dryers. The back is where the dryer draws the heat from and it sounds like you have plenty of heat. The only place the heat will go is up and that may be why you are geting burn marks. I wold also clean out the front where the lit filter is that to gets blocked up. I think if you check all that ad clean it out good the dryer should work just fine.
Jan 12, 2007 | Frigidaire GLER341A Electric Dryer
Dryers Logo
124 people viewed this question
Top Dryers Experts
