Hyundai tucson stereo comes up with CDP Error 7.
Followed owners manual by pulling the fuses and disconnecting the batteries with negative results.
  • 1 more comment
  • Anonymous Nov 03, 2008
    have same error message in recent bought 2005 Tucson, any solutions?
  • Anonymous Nov 21, 2008
    have same problem, any solutions?
  • Anonymous Nov 25, 2008
    Just came back from the Hyundai and they told me they would have to remove the radio and replace it for the little cost of around $400.00 and we all know that I can get a much better radio for around $200.00, so I told them no thanks.
I fixed it and here is my video.
http://www.youtube.com/watch?v=ufEzIUzI9aI
Posted on Feb 01, 2011
  • johwel Mar 06, 2011
    Easy to fix, reomve the adio, open the top cover, at the back is a small black clip that gets stuck when inserting a cd incorrectly, the tray then does not lower. Gently press it, it will jump back into position. Close. all should be fine.
  • Robert Thomas
    Robert Thomas Mar 31, 2013
    http://youtu.be/ufEzIUzI9aI
Is it hard to replace the starter on a 2005 Hyundai tuscan
1. Disconnect the battery negative cable.
2 Disconnect the starter cable (A) from the B terminal (B) on the solenoid (C), then disconnect the connector (D) from the S terminal (E)
.3. Remove the 2 bolts holding the starter, then remove the starter.
4. Installation is the reverse of removal. 5. Connect the battery positive cable and negative cable to the battery.
There are also video's on you tube showing you how.
Dec 22, 2016 | 2005 Hyundai Tucson
2005 hyundia tucson
Search Results
    2005 Hyundai Tucson Recalls - Cars.com
    www.cars.com/recalls/hyundai/tucson/2005/
    Cars.comLook up all NHTSA vehicle safety recalls for your 2005 Hyundai Tucson, and contact a nearby service center for free repairs.
    2005 Hyundai Tucson Problems, Defects & Complaints
    www.carcomplaints.com/Hyundai/Tucson/2005/
    7 days ago - The 2005 Hyundai Tucson has 199 problems & defects reported by ...January 11: Hyundai Genesis Recalled to Replace Dangerous Tires ...
    Hyundai Tucson Recalls ' RepairPal
    repairpal.com > Recalls > Hyundai
    Other systems that may be affected include: cruise control, push-button start, gear shifter, and Electronic Stability Control (ESC) system. Dealers will replace the brake light switch to correct this concern. ... The stop lamp switch may fail, affecting many vehicle systems including ...
    2005 Hyundai Tucson Recall - Learn About Recalls for 2005 ...
    www.automd.com > Recalls and TSBs > Hyundai Recall > Tucson
Jan 28, 2016 | Cars & Trucks
2011 hyundai tucson, battery is good, start relay clicks, won't start
The battery is bad. Almost any battery, unless tone dead, will read 12 Volts when there is no load attached. But put even the smallest load on it and the voltage can fall to that magic 7-8 volt range where things just stop working. If the battery is not that old, you'd best to a charging system check as well to ensure that the battery is not being discharged constantly during operation.
Nov 06, 2013 | Hyundai Tucson Cars & Trucks
Tucson 2008 radio doesn't work
Check the fuse , if it is blown, the radio won't work. The fuse box diagram is in your owners manual. It will also tell you what size fuse the radio requires.
Nov 13, 2012 | 2008 Hyundai Tucson
Radio not working
yOU NEED THE RADIO SECURiTY CODE TO FIX THIS. See THE DEALER UNLESS THE CODE IS IN WITH THE OWNERS MANUAL AND PAPERS GIVEN TO THE ORIGINAL OWNER OF THE CAR.
Oct 26, 2012 | 2008 Hyundai Tucson
2006 Hyundai Tucson Car - the battery is totally drained & dead so it wouldn't open with the remote opener. Now that we used the key when the car starts to get battery power back the alarm sounds...
this is for honda acura but it also might work for you too.
Open hood ensure new battery is disconnected.
Open main fuse panel cover under hood and remove horn relay (so you don't have to listen to the horn).
Use the key to lock the drivers door.
Connect the positive battery terminal.
Connect the negative battery terminal (security system will now activate, hazards lights will flash and horn would be going off if the relay was not removed).
Use the key to unlock the drivers door.
Get in, close drivers door.
Use the key to start the engine.
Security system will deactivate.
Get out of vehicle, reinstall horn relay, replace fuse panel cover, close hood.
Oct 15, 2017 | 2005 Hyundai Tucson
How do i disconnect the battery in 2007 hyundai tucson. we will be leaving it for six months.
Use a wrench to remove the negative battery wire at the battery terminal. once this is done,wrap the negative battery terminal in black electrical tape to prevent the terminal from contacting a ground. After the terminal is wrapped in electrical tape, place the terminal aside, and close the hood. (Don't let the terminal stick upwards,and cause hood closure interference).
Apr 17, 2010 | 2007 Hyundai Tucson Limited
CD stuck in 2006 Hyundia Tucson -How do you remove the CD/radio?
Answered a similar problem last week. Disconnect the negative battery cable for 10min. When you re-connect, the stero should reset and you should be able to get the CD out. If this works, will save you a lot of aggravation without having to remove the stereo. Best of luck!
Greg
May 18, 2009 | 2006 Hyundai Tucson
In my 2005 Tucson, my 5-cd player stopped working. I push the button to load the cd's, but nothing occurs. The dealership mentioned something about 'resetting' the radio... what is this, and is it...
The only solution I've seen is to disconnect the negative battery cable for 10min. After you reconnect, the stereo should reset itself and enable you to load cd's. If this fails, either a trip to the dealer for service or to an car audio dealer for an aftermarket stereo. I hope this solves your issue and wish you all the best!
Greg
May 15, 2009 | 2005 Hyundai Tucson
I need an Owner's Manual for a Hyundai Tucson
You can purchase on eBay (www.ebay.com). Contact the seller first to make sure it covers diesel.
Mar 22, 2009 | 2005 Hyundai Tucson
581 people viewed this question
 Grubhead
Grubhead
