Acer Aspire 5315 laptop suddenly turned off without warning. The battery light was flickering between orange and green very fast and . Now when I have it plugged in the light flashes rythmically orange and when I hover over the battery symbol in the bottom corner it says it is plugged in but not charging. What's going on with my computer?
  • 849 Answers
It looks that the battery pack finished its life, you might replace the battery pack.
Posted on Oct 21, 2008
Hdd light next to battery light flashes orange then green any ideas?
That is the head lite day lite system on or off or malfunctionJohnny
Mar 16, 2012 | Acer Aspire 5315 Notebook
Acer Aspire 5315 won't power up. The AC adapter has a green light on it, so it appears to be getting power. The battery indicator light does not light up at all when I try to power it up. Do you think it...
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
If this did not help, try disassembling the laptop & re-seating its main components like the memory modules, hard disk drive, CD/DVD drive, etc.
Dec 11, 2009 | Acer Aspire 5315 Notebook
My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Dec 08, 2009 | Acer Aspire 5315 Notebook
Acer 5920 -The power suddenly went off.
Probably this is due to surge current happend in the circute, butter not to switch on your lap. consult the service centre. Its is better not use the same adaptor for more troble shooting.
Oct 13, 2009 | Acer Aspire 5920-6727 Notebook
Starts charging then stops
It sounds like the battery has some dead cells and needs replacing.
Oct 12, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 Notebook will not power on
disconnect the battery from the laptop and only hook up the ac adaptor. Turn the laptop on and if it still cuts off after 5 seconds then reseat the memory back into its slots. Also make sure your air vents are not clogged with dirt or dust as lack or air flow can cause the laptop to shut off. If that doesn't do it then take out the hard drive and dvd drive and turn on the laptop. If the laptop still cuts off then it has to be a faulty motherboard at that point which means to much voltage is going thru and the components on the motherboard are not regulating it properly.
Jun 04, 2009 | Acer Aspire 5315 Notebook
Need to know how to fix my laptop?
remove the laptop battery and try to restart the laptop on AC power only
regards and please remember to rate us
Nov 28, 2008 | Acer Aspire 5315 Notebook
Acer laptop get turn off without warning
You Either Have the Wrong Drivers Installed, Or Missing Drivers, Or You Need A BIOS Update
I would Start With The BIOS Update......
Also Check Your Power Settings -- It Might Be Set to Turn Off..
Nov 17, 2008 | Acer Aspire 5315 Notebook
No juice
Sounds like a battery issue. Try powering up without the battery, just AC. If it powers properly, then the battery needs replaced. If it doesn't then it may be the power supply malfunctioning, or the motherboard.
Jun 19, 2008 | Acer Aspire 5315 Notebook
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
