Question about Goodman Heating & Cooling
I cleaned the filter in my Goodman furnace/ac unit and now I'm not sure as to which way it show go back in!
  • luannebain Oct 22, 2008
    The filter actually slides in on its edge; the furnace (where the motor and where the pilot light is located) is on the left and there is a large duct leading from the filter up thru the ceiling. Is the air blowing from the furnace toward the duct and up to the ceiling, or is that the duct work that brings the air to the furnace?
  • 3 Answers
Should have an arrow on one side showing air flow, if the filter is under the blower the arrow should point up, if you have a filter rack in your wall the arrow should point in, in otherwords the arrow should always point in the direction of air flow
Posted on Oct 20, 2008
I have a goodman heater and ac unit ,two stage ,problem the heat not very hot,feels more like luke warm.is there any way to addjust this.
Usually this is due to restricted air flow. So check the filter and ac coil (above the furnace) for filth and debris. Secondly adjusting the blower off delay dip switch on the circuit board could help some. Probably want to change it to a lower setting. Good Luck! :)
Dec 07, 2010 | Goodman GMS90703BXA Heater
I have a Goodman system and I have water leaking from the the small box next to my furnace. I have what looks like 3 lines running from unit to this box. One is a small copper one, another is a line...
the clear plastic hose is the condensate drain .. indeed they clog frequently .. lthat will allow water to overflow the pan that is desined to capture condensed water from the evaporator.. the plastic hose and the pipe it is attached to need to be cleaned out periodically ... allowing water to overflow can damage other things so its important to get the drain cleared .. however that drain has little to do with cooling efficiency .. your lack of cooling performance could be another problem ... sometimes the evaporator coil gets clogged (large finned unit behind where the overflow hose is attached inside furnace) .. that has to be cleaned once in a while but is tricky to do ... how often depends on how good the furnace air filter is and how often its changed ... as the evaporator becomes clogged with dust the cooling efficiency goes down .. same with the outdoor unit ... you have to wash out leaves and such periodically from the condenser coils .... if every thing is clean but the cooling efficiency is still low then have the unit checked for refrigerrant pressure .. it could be low .. of course make sure the furnace filter is not clogged ... also for cooling make sure all of the registers are open ... closing some can reduce overall efficiency ... make sure the outdoor unit fan is working properly ..
Jul 25, 2010 | Goodman Heating & Cooling
How to change the filter ?
Your filter is in one of two places.
Either its in a filter grille or its at the furnace/air handler itself. If its in the grille, simply remove and replace.
If its in the unit, it will be at one far end of the unit opposite where the electrical connections are. It's uncommon for Goodman to be filtered at the unit as they do not have an independent filter access panel but I have seen it.
If its not in either of these locations, you either do not have a filter installed or your installing contractor has installed a filter box somewhere that will need to be located.
Hope this helps.
Jan 10, 2010 | Goodman CLQ36AR49 Air Conditioner
Red light blinks 4 times, will only cycle once
the high limit is sensing the internal temprature of the furnace.If your filter is very dirty or you have to many of the registers/dampers shut it will cause the temp. of the furnace to exceed its rating and the high limit will open the circuit and shut down the flow of gas. Your blower will then run until the furnace has cooled and the switch will close and allow it to come back on. This is bad for your furnace, make sure your filter is clean and you dont have to many registers shut. If you have run the unit without a filter the problem could be much more sever requiring blower wheel and coil cleaning and possibly a cracked heat exchanger.
Sep 12, 2009 | Goodman GMS90703BXA Heater
Extremely long time to get cool air with 5 ton 13 seer goodman heat pump which is 3 years old.
Check your filter. Make sure it is clean. Make sure the outdoor unit is operational. (power on). Clean your condenser coil with a garden hose. If possible check your evaporator coil. If it is dirty clean it. Your furnace (or air handler) blower speed should be set on high. All of your registers (supply & return) should be open and unobstructed. Check for proper thermostat settings. If none of this information solves your problem , then your units charge needs to be checked. You could be over or undercharged with freon.
Good luck......
May 06, 2009 | Goodman Heating & Cooling
How often should the furnace should be checked and cleaned by a professional?
As suggested by manufacturers, a furnace must be cleaned every year.
May 03, 2009 | Goodman GMS90703BXA Heater
Need to Know Where to Change the Furnace Filter
On the bottom of the indoor unit should be a cover or tray. Sometimes a large grill inside the house, close to the unit is where they are placed. Good luck
Apr 23, 2009 | Goodman Heating & Cooling
Limit Switch
It is rare that a limit switch goes bad. It is a safety control. If it is shutting off your furnace there is a problem that it is protecting you from.
If the limit switch is shutting the unit down your furnace is overheating. Check the filters. Check for any obstruction in the blower assembly. Check to see if you can raise the blower speed. Make sure all registers are open in the house. Your evaporator coil could be obstructed if you do not take good care of your filters.
Feb 28, 2009 | Goodman GMS90703BXA Heater
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
85 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
