Question about Canon PIXMA MP150 All-In-One InkJet Printer
Broken front door
Granddaughter broke the hinges in front door/gate/paper holder. need a replacement part. where can i order one?
  • 628 Answers
Sorry to say, but you probably won't be able to get a replacement part from anyone, unless you find a used broken printer. Those printers are so cheap that no one has any parts for them. Technicians couldn't justify the charge for fixing one. Better to either live with the break or buy a new printer.
Posted on Oct 20, 2008
I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Dec 27, 2009 | Dometic RM2652 Refrigerator
Refrigerator door swings open too far; does not stop. Is this a hinge assembly that is broken? Part found in the floor.
Yes it is a hinge cam that broke. Can be ordered on the GE website. A no pro job to replace. A little patience and time about 30 minutes.
Dec 16, 2009 | GE 25.2 cu. ft. Side-by-Side Refrigerator...
Printer Error
on the ip4300, the clips that hold the front of the cover on are on the bottom, not the front as shown in the service manual for the 4200.
May 21, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
I have a Maytag Model MGR5770ADW and it appears that the left side door hinge spring is broken. How do I remove the side panel to investigate? Thanks, Ken
no need to remove the side panel, the door itself lifts off the hinges, and it will be reall obvious, if its broke, theres no servicing it just replace, and its done from the fornt, 2 screws and the hinge falls into the unit ( can grabit from pulling out lower storage drawer. part number (74011141) , might as well replace he 2 hinges one broke whos to say the right one is gonna last much longer
Dec 07, 2008 | Maytag MER5755QAS CleanDesign Electric...
8820DN hinge problem
To answer Meyerson's questions:
My symptoms did not include papers jamming in the ADF -- in fact, the ADF didn't work at all due to the broken left hinge.  :(  Also, I don't recall having any unusual problems with the ADF jamming frequently before the hinge broke to the point where the ADF didn't work at all.
I obtained the replacement ADF left hinge assembly by searching online for a parts dealer.  I believe I ended up ordering the part from Precision Roller.
I hope this helps,
-Barb
Apr 01, 2008 | Brother MFC 8820D All-In-One Laser Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
61 people viewed this question
old marine
old marine
