Question about Samsung LNT3242H Television
Samsung LN-T3242HX Hi Welcomejee Well I opened it up again, and resoldered the ccfl where it goes into the board. Still no luck. Does the ccfl actually have to be touching the lead on the board? or would the solder carry the current if was not right up against the lead? I am almost positive that it is making connection on the board, but I am no guru at soldering techniques. Would any of the ccfls light up if that one is not making the connection? Do you know of any way to test the ccfls while they are out of the unit? Thanks for all your help!
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Samsung LN-T3242HX LCD TV
Hi Compgeek09
Please check CCFL is hooked in connector properly, all connectors of back light inverter board are plugged correctly, check also other connectors of removed boards while CCFL replaced.
It doesn't seem issue of back light inverter board nor its related to ground wire of power plug to wall because tv was working before replacement of CCFL.
Posted on Oct 19, 2008
Would not turn on until I slapped it
There should be some loose connection or dry solder in the power supply board. Resolder all such points. Capacitors can not cause this problem unless at least one of their legs is loose. Also tighten all the connctors and cables.Good luck.
Jan 10, 2014 | Samsung LN-T1953H 19 in. LCD HDTV
I have a LN-T4061F Samsung LCD, I'm seeing vertical bars across the screen
most of the time this is the ctrl board its like a graphic card tells the screen what to show,but the cable from that goes to main board sometimes this is the cause of lines/open it get no of control board it has a 30 pin thin lead going to main board and google it easy to replace plug n play
Nov 10, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
HI I HAVE A 40" SAMSUNG LCD MMODEL LN-T4061F MY QUESTION IS YOU TURN REMOTE ON AND TV JUST CLICKS NO SOUND OR PICTURE WHAT COULD IT BE TAHANKS
POSSIBLE OF SOME COMPONENTS IN POWER AREA HAD BEEN DAMAGED, AREAS TO CHECK IS POWER AREA, NEAR FLYBACK TRANSFOMER...THE BEST OPTION IS TO RESOLDER THE MAIN BOARD..THEN TRY IT
Oct 14, 2009 | Televison & Video
Polaroid TLA-01911C TV - I seem to have the same
You probably have a bad inverter PCB. It is a skinny board by itself over on the left side of the back of the panel.
Oct 12, 2009 | Polaroid TLA-01911C TV
Samsung 32 lcd tv backlight off after 4 sec. audio ok
If your TV is staying on and you hear audio after the picture goes dark, then you have a problem with a CCFL or the inverter circuitry that drives them.
Most likely an inverter problem.
Like a bad xformer (usually fogged up plastic wrapper)
Or a bad cap (bulged, swollen, cracked)
Or maybe a shorted IC or transistor (test for short circuit between the different pins of the device)
Oct 08, 2009 | Samsung LN-S4051D 40 in. LCD Television
Samsung 32" LCD tv, No picture with audio
i will first resolder all ic`s and connections,especiall on the crt board,clean around the flyback at the abl circuits,check for open or changed valued resisters in abl circuit and the video b+ on the crt board (usually 165-200 volts) check also the screen voltage (G2) volts,should be around 250 - 400 volts.
Sep 18, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Hi Compgeek09
Oct 19, 2008 | Samsung LNT3242H Television
Samsung LN-T3242HX
Hello Compgeek09,
It appears that one of the CCFL lights might have broken behind the screen and that is why the TV would turn on for 1 second and goes off after.
The noise you are hearing could peaces of shattered or broken light and you would have to remove the screen and to be able to fix it, if you are up for the challenge.
Let me know if you required further assistance.
Jun 11, 2017 | Samsung LNT3242H Television
Same problem...
no usually the power board and the inverter board are different boards. there are cheap brands that are all in one. so if you only have one board inside the back cover then the answer may be yes, however the power board (section of the main pcb board that supplies power ) is distinctly separated due to heat and has several large capacitors in its section.
May 28, 2008 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
60 people viewed this question
Jerry Greenberg
Jerry Greenberg
