Question about GE 106591 Coffee Maker
GE Model 169164 Paper Filter Size?
What size cone filters do you use in the GE model 169164 digital coffee maker? The manual says you can use paper filters, but doesn't give a size.
  • rwarner1 Dec 14, 2008
    I would like that info also.
# 4 coffee filters made by militta. I have the same maker and i hate all the coffee grinds in the pot
Posted on Jan 16, 2009
I have signature classics 12 cup coffee maker with timer model# xq626-wt svc code 2764 i can not find a filter for it
http://www.fantes.com/coffee-filters.html According to this link and others, we need to use a #4 filter. I placed my old #2 cone filter in this machine (I just bought it tonight) and it is short about one inch...so the next step up would be a #4. The bottem of the basket that comes out, would lead one to believe it is a cone shape cone. You can also opt for a perminent gold cone filter. But, use the paper one first to be sure of the size. I am getting #4 tomorrow and test this machine out. It has mixed reviews on line. Coffee Maker is the brand name and I only see it sold at Home Depot from my on line searches. Good luck....blkqueentech at yahoo dot com
Nov 13, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
I need to purchase new filters for GE coffee-maker model number 169164
I'm not sure whether you mean the charcoal filters or the basket filter for the coffee. I have the exact same basket that I bought years ago as a replacement for a different pot, so I doubt that would be a problem. You can try your local Walmart for the charcoal filters since this model was sold exclusive contract with that chain. Depending on the size of your Walmart, you might have to special order those. Otherwise, they are available at most super centers. Just as an added measure, you might want to try washing the filters and using a coarser coffee grind before you buy new ones.
Dec 19, 2009 | GE 106591 Coffee Maker
Broke glass carraffe, need to replace model 169164
I replaced my broken carafe on model: 169164 by purchasing a RIVAL 12 cup coffee maker PIL-HC08104 from WalMart for $10.24 and simply put my black handles on the new pot whaic had white handles. The pot appear to be exactly the same.
Nov 01, 2009 | GE 106591 Coffee Maker
Cusinart 12 cup grind and brew overflows with grinds and water
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Replacement Part - GE Coffee Maker 169164
Need spare parts or accessories, please call our Customer Assistance number.
1-877-207-0923 (U.S.) or 1-877-556-0973 (Canada)
Just give them that part number, and they can order it for you
Mar 16, 2009 | Coffee Makers & Espresso Machines
Ge 169164 put in 12 cup water stop at 4cups
I have the same problem the water filter is on too tight try lifting the filter a Little bet high or twist the filter or your filter might need to be change hope this answer works for you.
Jan 27, 2009 | GE 106591 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
GE 169164 coffee maker problem
*** HOW TO RESET THE GE 169164 COFFEE MAKER ***
After endless online searches yielding the same results (nothing useful), I figured out how to reset this coffee maker.
While coffee maker is plugged in and the evil little blue light is mocking you relentlessly, press and hold the 1-4 button and the TSB button simultaneously for 3 seconds or so. This will cause the device to exit it's error status and allow normal use of it.
Aug 01, 2008 | GE 106591 Coffee Maker
GE 106591 Coffee Maker Logo
243 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
