I have a Sony Grand Wega KF-60XBR800 Sreen goes black after it has been on 2 minutes, fan speed changes and standby light blinks 34-35 times then screen comes back on this cycles continuously. I have mounted a fan next to lamp area but problem is exactly the same - no change at all. Any ideas
SOURCE: sony dead !!!!
Jedi,
Sounds like lamp and driver need to be replaced again... Lamp is Sony p/n# A-1052-675-B and the driver p/n# 1-468-798-14
Bill
SOURCE: Sony grand wega started turning on and off continuously
The usual problem is that the lamp needs to be replaced. However, there is no guaranty that lamp replacement will correct the problem.
To figure out how to replace the lamp please visit
The frequently asked questions for Grand WEGA KF50XBR800 50 in. Rear Projection
http://www.agoraquest.com/viewforum.php?forum=70
SOURCE: SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
SOURCE: Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
