Question about Frigidaire Gallery Series GLRT86TEK 30" 18.3 Cu. Ft. Top Mount Refrigerator w/ 4 Half-Width Glass Sh...
Freezer not getting cold enough
Lately, I have noticed that my Frigidaire GLRT86TEKF freezer is not freezing anything. It does get cold in there, but you can't even freeze some ice. There is cold air coming out of the back, but I also noticed an ice build-up in the lower right of the freezer section.
Any suggestions are appreciated.
  • 61 Answers
It would sound like you ether have a defrost problem . or a drain heater problem or posibly even a short refrigerant problem / if you can identify the location of the defrost timer located on the underside of the compartment divider unless im mistaken with this modle . you can manually put the fridge into a defrost. listen close to the freezer and see if you can hear ice water sizeling on a heater in about 5 or 10 minutes. if yes then you know the heater is working and you replace the timer. if no then alow the timer to come out of defrost on its own. if it does then the time is running ok and youll have to look for a nothe problem. the other two problems would have to be exposed by a pro. if it is a refrigerant shortage this is normally under 5 or 7 year woranty . chck you lables or woraty info on line. hope this was helpfull
Posted on Oct 20, 2008
  • john berlinghof Oct 20, 2008
    please rate this solution
Freezer is not freezing
Good Morning Friend,
I understand that your Frigidaire freezer is not getting cold enough to freeze your food. I suggest cleaning the compressor, underneath your appliance, by using an attachment on your vacuum. I also suggest lowering the temperature and giving your freezer 4-24 hours to stabilize at that temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dishwasher status has changed successfully. If further troubleshooting is needed, please leave me the model number of your freezer. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Frigidaire Freezers
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer not freezing like it should
Yes that is hte panel in which "skeeter 140 " was refering
Jan 14, 2009 | Frigidaire FRT18FS6C Top Freezer...
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Frigidaire Gallery Series GLRT86TEK 30" 18.3 Cu. Ft. Top Mount Refrigerator w/ 4 Half-Width Glass Sh... Logo
115 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
