Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
30 in riding Craftsman riding mower electrical problem
This little mower has an electric starter motor, the wire on the negative post on the battery broke and I can not find where should be connected. Can you help
  • 48 Answers
Anywhere on the body of the tractor
Posted on Oct 24, 2008
Is the Starter Solenoid hard to replace on a Craftsman 30 riding mower?
I don't know this exact model, but it should be quite easy if you have some basic tools. Where does the large cable from th (+) positive side of battery go? In some cases the solenoid is mounted on the starter, in others it is bolted to the frame of the machine, usually close to the starter. Be sure to remove the (-) negative battery cable before starting any electrical work.
Jun 22, 2018 | Craftsman Garden
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
What should I do; I have a craftsman 26 hp 54" deck yard tractor that will click but will not start?
Test starter by using jumper cables from negative pay on battery to a good ground (bare metal on the frame somewhere) and positive post to starter post ( should be a thick red wire attached to starter post. Be careful because the starter will turn bypassing all safeties. You should have the key off, parking brake on, blades disconnected. If starter turns, starter is good.
Jul 05, 2014 | Craftsman 26 Hp 54" Deck Yard Tractor
Riding lawn mower stopped working, now it just makes a clicking noise when you turn the key, the grass was pretty high when this happened...did the engine blow?
the battery is just probably low,, make sure it has a full 12 volts or better, check to make sure the battery posts are clean and making good contact ,,, riding mowers charge slowly, and if the current can't charge the battery , then the mower is just draining it as you run it, hitting a large clump of grass could stall out the motor, But I doubt it Blew it up,, check those items ,, Good Luck
Jun 16, 2011 | Craftsman Garden
Hello - I have craftsman 42 inch deck mower with a kohlar engine that does not start. Battery appears fine, when I turn it - it clicks with the head lights turning on. Ang ideas on how to get it started?...
With the key in the run position, using a jumper cable, jump from the positive post on battery to terminal on starter motor. If it runs you have a solenoid or ignition switch problem. (assuming all electrical connections are clean). If it doesn't crank the battery is the culprit.
Oct 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Riding mower-starter relay clicks-no start even with jumpers.
The frame of the tractor is the same thing that starter grounds to,so yes ,put the ground any where on the frame or engine block to test the starter.An easier way to test everything is to cross over the large posts on the solenoid with a screwdriver and if it turns then the starter is not the problem.Then you will need to put power from the post on the solenoid that has the battery positive connected to it ,to the post on the solenoid that should come live with the key,if it starts then then you likely need an ignition switch if not you need the solenoid.
May 31, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I replace the starter on my 2004 Grand Am?
Alero, Grand Am 1999-2005 Repair Guide
Starter - Removal & Installation
2.2L Engine
  1. Before servicing the vehicle, refer to the precautions section.
  2. Remove or disconnect the following:
    Negative battery cable Starter electrical connector Starter motor
    Fig. Starter mounting-2.2L engine
To install:
  1. Install or connect the following:
    Starter motor. Torque the bolts to 30 ft. lbs. (40 Nm). Starter electrical connectors Negative battery cable
3.1L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
    Negative battery cable Starter electrical connectors Starter motor
To install:
    Starter motor. Torque the bolts to 32 ft. lbs. (43 Nm). Starter electrical connectors Negative battery cable
3.4L Engine
    Negative battery cable Flywheel inspection cover Starter electrical connectors Starter motor
To install:
Starter motor. Torque the bolts to 32 ft. lbs. (43 Nm). Starter electrical connectors Flywheel inspection cover. Torque the bolts to 89 inch lbs. (10 Nm). Negative battery cable
I hope helps with this. Good luck (remember rated this help).
Dec 29, 2009 | 2004 Pontiac Grand Am
I have got a Craftsman model 917.270821 19.5 electric start 42" mower and cant get it to start I have replaced the starter and had the battery checked and all is good there, but dont seem to be gettin
check the wires from the back of the ignition and also the small wire that connects to the starter, if you get a 12v test light check each wire individually by holding the test light on the wire and have somebody turn the key, the test light should come on if the power is going through the wire.
If there is no power the ignition may need replacing
May 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Oct 04, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
205 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
