Question about Yahoo Messenger
Black webcam window
My webcam window is black i've done every thing i could and my webcam window is still black
  • tonyleemm Apr 26, 2009
    my webcam shows a black pic when using it on yahoo
  • tonyleemm May 11, 2010
    how do i take these steps..please
  • 507 Answers
You should make your webcam driver active under the ‘Microsoft WDM Image Capture (Win 32)’ driver using the 'Options > Video Source' hot button above the preview window.
Posted on Oct 24, 2008
Hello.I had to uninstall and reinstall eatcam.Now,the recordings are terrible.I can't even see what I've recorded.I've uninstalled and reinstalled it over and over again.The recordings are
you might need more software or updates.
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
Apr 27, 2013 | EatCam Webcam Recorder for Yahoo Messenger
I've installed windows 8 os in my acer aspire 5580 laptop,but inbuilt webcam not working
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
Jan 17, 2013 | Acer Aspire 5580 Notebook
Hp pavilion zx5000 power up but black screen
My suggestion would be to unplug the cord from the connection on the
computer, then remove the battery. After you've done that, press and hold the
On/Off switch for about 60 seconds, then, after you've done that connect
everything back together, and see if it will reboot. If not, check the hard
drive, and the ram and make sure they are all connected tightly.
Oct 17, 2012 | HP Pavilion zd7000 zx5000 zv5000 presario...
ASUS UX32VD Zenbook Webcam stopped working
i got the same problem with my new UX32VD.
the camera worked properly for the first week but after that suddenly it's stop working.
any solution?
Sep 05, 2012 | ASUS UX32VD-DB71 Zenbook 13.3" Ultrabook...
OrbiCam Problem. Webcam not Found.
click on right side of screen and then type camera in the search box . mine does not always want to come up. either but when I use SKYPe it is active .
Mar 04, 2017 | Acer TravelMate 4222WLMi Notebook
I ve followed the steps but after the installation process i recivied message " an error occured while setting up integrated web cam " then a window appers informing me that the installation has completed...
Restart the computer then try the webcam if it works. If not, go to support website of dell then download the latest driver for the webcam, make sure that you have the right OS in the selection, uninstall the driver in device manager then install the new driver you downloaded. If the webcam still doesn't work check BIOS if the intergrated webcam is on or detected if it is off turn it on, if it is not detected you'll need to replace it, if you were able to turn it on you've done all the things above. try to reinstall the OS after that redo the procedure above and in that time if it still doesn't work. You'll end up replacing it again.
Feb 12, 2010 | Dell Studio 1535 Notebook
Connection probleme:
1. connect the camera.
2. when the pc identified the camera and recommended to locate the driver, select locate and install.
3. after instalation done, restart the pc.
Jan 04, 2008 | Logitech QuickCam Messenger Web Camera
Yahoo Messenger Logo
754 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
