Question about Proscan 19LA25Q 19 in. LCD Television
Channel search my proscan was unplugged for a couple months and i have tried the channel searching for over 3 hours and it keeps tellin me no channels found no signal HELP!!
    New Friend:
  • 42 Answers
Go to set up see if tv is set for antenna or cable. Set it for which ever you have.
Posted on Oct 20, 2008
Proscan PLEDV 1945A-B will not recognize cable. Auto channel scan results in no channels found
Do you have the converter box to convert the incoming signal from digital to analog, you must have this to receive broadcasts.
Nov 04, 2016 | Proscan Televison & Video
My Proscan flat screen, i can't get it to search channels automatically. it wont turn on without plugging and unplugging. Help Please!
Go to the link and ask the question there.
Oct 26, 2016 | Proscan Televison & Video
Sound but no picture How do I fixx it
If you are using RCA cables be sure that the colored cables go with the corresponding input plugs, after checking the cabling try powering off then powering on your unit. Some units require a quick channel search and setup, which is usually found under the menu option.
Dec 30, 2014 | Proscan Televison & Video
The tv keeps saying run auto channel scan
I have run the auto scan many times and it never finds any channel. I found that you have to put it on the HDTV, PC, AUDIO channels in order to watch or connect anything on the TV. Try doing that.
Sep 13, 2013 | Proscan PLDED3273A 32" LED 720p HDTV with...
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Tv does not respond to remote commands
You need to isolate the problem.
1) Unplug the TV for a few seconds and then plug it back in.
2) Operate the TV with the buttons on the TV. (Channels etc) I presumed you have scanned in the channels.
If no problem found then do this for the remote.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Now try the remote to see if it works. If it fails you will need a new remote.
Mar 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
No signals found when searching for channels at setup
you need to press the channel up button 3 times if yo get message as please connect av sources. then do the manual channel search for 2 times. it should solve the problem.
Oct 13, 2008 | Sanyo DP32746 32 in. LCD Television
My Vizio plasma TV won't change channels with the remote or side buttons, but if I input a channel number, it will change that way.
Try unplugging the TV for a few minutes and then doing an auto channel search through the menu button. That has solved my problem, at least for the time being.
Aug 11, 2008 | Televison & Video
Proscan 19LA25Q 19 in. LCD Television Logo
148 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
