Question about Soleus KY-34 Portable Air Conditioner
Lost Manual How do I reset the temperature for cooling and heating?
You can either look or download and save any manual for any model on the website www.soleusair.com
Posted on Jul 25, 2009
How do I stop the heating coming on during the night?
Set automatic day and night temperatures. Forget about manual setting. Your furnace will start at night only to maintain the temperature you set. However, there is a minimum threshold where your furnace will start regardless of the temperature you set if there is a sharp drop in temperature.
Jan 31, 2017 | Heating & Cooling
What is the on/off temperature (heat) range for a RTH111 series
Heat range: 40 to 90 degrees F
Cool range: 50 to 99 degrees F
1 degree deadband
Here's the operation guide:
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2603EF.pdf
Please mark my answer as helpful.
Jan 05, 2015 | Honeywell Digital Manual Heat/Cool...
I have a visionPro 8000 in a system with heat/AC/ and heat pump recently installed. the vision pro does not have an auto position on the function switch. The manual, in a footnote says that only special...
Not sure which 8000 you have but it looks like all of them have the auto changeover option. Press system, you should see "heat/cool/auto/off" this is the auto changeover. So system is on auto, fan should be on auto. Send model number if you can't get it!
Jun 26, 2017 | Heating & Cooling
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
I've lost my manual, and am unsure what the heat
You posted under water heater.
Open following link for adjusting water heater temperature on typical gas and electric water heaters:
State electric has ABC
White Rodgers gas thermostat has ABC
Honeywell gas valve has ABC
Each is shown on following link:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
60 degrees C is 140 degrees F.
You can get burned pretty quick at 140 F.
I suggest 125-130 F and see if that works
First aid for burns is to apply cool water immediately.
Jul 09, 2011 | Rheem Water Heaters
I am trying to lower my temperature to cool my house but it will not go any lower than 78, is there anything i can do to reset or lower the temperature?
Many t-stats will not let you go within less than 2 degrees of the heat set point....
Lower the heating set point and then you will be able to lower the cooling setpoint..
heatman101
May 10, 2011 | Honeywell Heating & Cooling
How do you reset the unit so it is no longer on program mode
From the Operating Manual: Manual Operation for Non-Programmable Thermostats Press the SYSTEM button to select Heat or Cool and use the [Up] or [Down] buttons to adjust the temperature to your desired setting. After selecting your desired settings you can also press the SYSTEM button to select AUTO to allow the thermostat to automatically change between Heat and Cool. Manual Operation (Bypassing the Program) Programmable Thermostats Press the [Up] or [Down] buttons and adjust the temperature wherever you like. Then press HOLD. This will override the program. The HOLD feature bypasses the program and allows you to adjust the temperature manually, as needed. Whatever temperature you set in HOLD will be maintained 24 hours a day, until you manually change the temperature or press RUN to cancel HOLD and resume the programmed schedule. ____________________________________________________ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Jan 22, 2011 | White Rodgers White-Rodgers 1F85RF-275...
My nonprogrammable Honeywell thermostat th5110D is no matching temperature settings (desired and actual). There is about 4 degrees difference. I have looked at the manual and reset the system and changed...
Your thermostat is reading the temperature where it is located.
If it is located next to a heat source maybe it is picking up that added heat .
Try relocated your thermostat
May 30, 2017 | Heating & Cooling
Lost Manual
it is probably on airconditioning (cooling), if you have Toshiba remote it should be a picture of a sun meaning "Heat", never go for "Automatic" wich cools and heats succsessivly to maintain ONE temperature, go for "Heat" when its cold!
Jul 05, 2008 | Heating & Cooling
Soleus KY-34 Portable Air Conditioner Logo
211 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
