Question about Gateway Computers & Internet
I cant find my recycle bin - Gateway Computers & Internet
  • 749 Answers
To resolve this issue in Windows Vista, follow these steps: 1. Click Start, and then click Control Panel. 2. Click Appearance and Personalization, click Personalization, and then click Change desktop icons. 3. Click to select the Recycle Bin check box, and then click OK. To resolve this issue in Windows XP, use one of the following methods. Method 1: Use the program that removed the Recycle Bin to restore the Recycle Bin
loadTOCNode(2, 'resolution'); If you used the TweakUI program to hide the Recycle Bin, follow these steps to restore the Recycle Bin to the desktop: 1. Click Start, and then click Run. 2. In the Open box, type regedit, and then click OK. 3. Locate the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel 4. In the right pane, right-click the following registry DWORD value, and then click Modify: {645FF040-5081-101B-9F08-00AA002F954E} 5. In the Value data box, type 0, and then click OK. (The TweakUI utility sets this value to 1 to hide the Recycle Bin icon.) 6. Quit Registry Editor. Method 2: Edit the registry to restore the Recycle Bin
loadTOCNode(2, 'resolution'); Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/) How to back up and restore the registry in Windows
Note This procedure does not work if the system administrator used a Group Policy setting to hide the Recycle Bin (or "All Icons") on the Desktop.
To edit the registry to make the Recycle Bin icon reappear on the desktop, follow these steps: 1. Click Start, and then click Run. 2. In the Open box, type regedit, and then click OK. 3. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Desktop\NameSpace 4. Right-click the registry key that you located in step 3, point to New, and then click Key. 5. Type {645FF040-5081-101B-9F08-00AA002F954E}, and then press ENTER. 6. Click the new {645FF040-5081-101B-9F08-00AA002F954E} key that you created in step 5. 7. In the right pane, double-click the (Default) entry. 8. In the Edit String dialog box, type Recycle Bin in the Value data box, and then click OK. 9. Quit Registry Editor.
Method 3: Use the Group Policy Object Editor to restore the Recycle Bin loadTOCNode(2, 'resolution'); If the system administrator used a Group Policy setting to hide the Recycle Bin or "All Icons" on the Desktop, you may have to contact the system administrator to restore the Recycle Bin icon.
Note The following procedures works only on Windows XP Professional.
The system administrator can either use the Group Policy Object Editor (GPEDIT.msc) or manually remove the registry information (that was created through the Group Policy Object Editor) for the Recycle Bin to restore the Recycle Bin icon to the Desktop. • To use the Group Policy Object Editor to restore the Recycle Bin: 1. Click Start, click Run, type GPEDIT.MSC in the Open box, and then click OK. 2. Under User Configuration, click Administrative Templates, and then double-click Desktop. 3. Double-click Remove Recycle Bin icon from the desktop. 4. Click the Setting tab, click Not Configured, and then click OK. • To use Registry Editor to restore the Recycle Bin: 1. Click Start, and then click Run . 2. In the Open box, type regedit, and then click OK. 3. Locate the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\NonEnum 4. Click the registry key that you located in step 3, and then in the right pane, click the following registry DWORD value: {645FF040-5081-101B-9F08-00AA002F954E} 5. On the Edit menu, click Delete, and then click Yes. 6. Quit Registry Editor.
The Recycle Bin icon reappears on the Desktop.
Posted on Oct 20, 2008
    Genius:
  • 1,226 Answers
Please try right click on the desktop and then properties, click desktop tab and customize desktop. then click restore default setting. this will resolve the issue. however if the same happen then you have to repair the windows installation.
melnavz
Posted on Oct 19, 2008
Do i need to put my Recycled bottles in a trash bag then in my Blue Recycle Bin? Or can i just throw the Bottles in the bin?
Do NOT put your recycleables in a trash bag. Put them straight into the bin. It saves you a bag and saves someone at the recycle plant from having to remove it and throw it away.
Jan 04, 2017 | Green Living
Deleted recycle bin
It depends on what version of Windows you are using. If you open Windows explorer by pressing the "windows" and E key at the say time you should see it. Otherwise, modify your display settings as the option to show the recycle bin is usuall there. Another thing you can do to empty the recycle bin is to run a disk cleanup, as this will give you the option to empty the recycle bin as well.
Jul 29, 2013 | Fujitsu Computers & Internet
How to rename recycle bin
I'm am sorry I am a little confused, you want to rename the recycle bin Registry key, but not rename the actual recycle bin? I need a more detailed explanation of the problem that is very specific. Also, just out of curiosity, why do you wish to rename the recycle bin? I am just curious.
Ryan Frame
Creative Energy Associates Technical Center
Aug 22, 2009 | Nolo How to Change Your Name in California...
Recycle bin
1. Click Start, and then click My Computer. 2. On the Tools menu, click Folder Options. 3. Click the View tab, and then click to clear the Hide protected operating system files (Recommended) check box. 4. Click Yes when the warning message appears, and then click OK to close the Folder Options dialog box. 5. Click Folders on the toolbar.
Note If Folders is not visible on the toolbar, point to Toolbars on the View menu, and then click Standard Buttons. 6. In the left pane, under Folders, locate the Recycle Bin folder, and then drag the Recycle Bin folder to the desktop. 7. On the Tools menu, click Folder Options. 8. Click the View tab, and then click to select the Hide protected operating system files (Recommended) check box. Click OK.Note This procedure does not re-create the original icon. However, this procedure restores most of the features of the Recycle Bin, including the following: • Delete a file by dragging it to the Recycle Bin icon on your Desktop. • Retrieve a file that you deleted by double-clicking the Recycle Bin icon on your Desktop, right-clicking the file that you want to retrieve, and then clicking Restore. • Empty the Recycle Bin by right-clicking the Recycle Bin icon on your Desktop, and then clicking Empty Recycle Bin. When you use these step to work around the problem, you cannot right-click the Recycle Bin shortcut to access the Recycle Bin Properties. To set properties for the Recycle Bin, follow these steps: 1. Double-click the Recycle Bin shortcut on the Desktop. The Recycle Bin folder opens. 2. In the upper left corner of the Recycle Bin folder, right-click the Recycle Bin icon, and then click Properties.
Mar 31, 2008 | Acer Aspire 5500 5570-2609 Laptop
Recycle bin got deleted
Error message: "Not enough free space to delete 'filename'"
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang. To resolve this issue, use one or more of the following methods. * Empty the Recycle Bin Use the following steps to empty the Recycle Bin: 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Empty Recycle Bin" 3. Tap "Yes" when asked to confirm the file deletion. * Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete". * To make additional space available for the Recycle Bin. Use the following steps to change the properties of the Recycle Bin. 1. Depress the "Alt" key and tap the Recycle Bin. 2. Tap "Properties". 3. Tap the slider to the right.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Windows CE device
Sep 14, 2005 | NEC MobilePro 880
Windows CE device
Sep 14, 2005 | NEC MobilePro 750
Windows CE device
Sep 14, 2005 | NEC MobilePro 250e
Computers & Internet Logo
278 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
