Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Dryer not heating up
I have an older Maytag Atlantis Dryer that does not heat up. I see that the igniter lights up but the burner does not ignite. I cleaned the exhaust sensor - unpluged the electrical connectors on the sensors and burner, they seemed clean and repluged. Anyone have a suggestion...so that I do not have to replace parts that do not need replacing.
Exhaust is clean; good gas hook-up.
  • 61 Answers
Best guess is that one of the two solenoid coils on the gas valve is faulty, one has two connections and the other has three. Always replace BOTH solenoids even if only one has failed.
Posted on Nov 05, 2017
jsrock516
  • 5911 Answers
SOURCE: After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Posted on Apr 29, 2007
Amigaman
  • 248 Answers
SOURCE: Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Posted on Nov 11, 2007
appldoctom
  • 311 Answers
SOURCE: Gas dryer doesn't heat up
,when you start your gas dryer you should here two clicks, if so then your ignitor should begin to glow if two clicks and no glow [its your ignitor] but you can use a volt meter and make sure 110 volts at ignitor if voltage replace ignitor with new.if not two clicks then its going to be your thermal fuse its in the same area as the burner Therese two kinds[only one in each dryer tho],both white having two wires and small, one looks like a missile the other a fling saucer.ither kind you can put the two wires going to it to gether ,isolate them with tape and try heating.if heats replace.now if fuse you need to check for any blockage,inyou house or dryer.over heating can cause the fuse to open if i can be of more help you can email thru fixya God bless ,tom
Posted on Jan 10, 2009
Healeyman
  • 1198 Answers
SOURCE: maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Posted on Apr 28, 2009
vickygomar
  • 460 Answers
SOURCE: no heat, exhaust clean and gas flow good.
I hope this helps U
copy n paste http://www.partselect.com/ModelFrames.aspx?ModelID=153823&ModelNum=MDG8600AWW&ManufactureID=1&Selected=51311&Position=6&mfg=Maytag&Type=Appliance&Mark=6
let me know if this works for U
"Was this helpful?"
Posted on May 09, 2009
Maytag gas dryer. Heating element comes on however, not every time does the gas click on so I get heat. Gas line is fine. What causes the click that gets you heat for dryer?
That would be the "igniter" you hear. You may have a problem with the igniter or the 2 coils on the gas valve. Below are links to the parts.
Igniter
Coils
Nov 28, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
The Maytag Atlantis dryer (gas) does not appear to be igniting the burner when it is turned on. The problem has gradually become more frequent over the last couple weeks. Now, it almost never lights up. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My Maytag Atlantis gas dryer does not get hot. What should I look at?
check out the ignition spark ignitor
that makes the burner to heat up
Mar 11, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Aug 13, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Igniter works fine but there is no flame so therefore no heat
Replace the coils on this burner assembly. this will fix this issue you are having at this time.
The coils open and close the valves, which are responsible for gas flow. these coils are damaged.
May 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer does not heat
Perhaps the thermal fuse is open. All thermostats and thermal fuses should be closed for continuity at room temperature on this dryer.
Go here for more Maytag Atlantis Dryer repair help: http://www.repairclinic.com/0047_8.asp
www.RepairClinic.com
Feb 01, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Jan 10, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
As you are looking at the igniter you may notice a little rectangular sensor to the left.
This tells the dryer that the igniter is glowing and it is OK to open the natural gas valve. If this sensor isn't working, the gas valve remains closed
Once the burner is lit, there is another sensor above the flame that is round. (flame sensor) This tells the dryer that the flame is lit.
If this sensor isn't working the dryer turns off the burner after a brief period.
This sensor can be cleaned or replaced.
Jun 22, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
106 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
