Question about LG WM-2277HW Front Load Washer
LG WM-2277 displays LE
When sarting a wash, water goes in for a few minutes and washer displays LE
I have exactly the same problem. The motor is covered by a 3 year warranty. You'll have to pay for labour. I will not buy any LG product in the future. Its junk.
Technician said the motor requires replacing. I believe its a computer module error. Some people were advised to unplug the machine for 2 hours and allow the computer to reboot! This does not sound like a mechanical issue. Whatever it is the machine is poorly developed and completely overpriced. Customer service is non-existent. Website is cumbersome and unhelpful. looks like a money grab to me by Lucky Goldstar (yes, LG is the new name for Goldstar, a low end appliance manufacturer of the past)
Disatisfied Customer (5 weeks out of warranty)
Richmond Hill
Ontario
Posted on Oct 21, 2008
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
Feb 23, 2015 | Samsung 3.7 CuFT VRT Front Load Washer
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Wm2016cw
LE errors mean the motor is locking up and cannot turn the drum. If the drum turns freely by hand then it could be https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/406-200-684484-/LG-LE-MOTOR-ERROR-Motor-Stator-overheat-or-connection-error-WM2016CW
If that is not the problem then the motor needs replaced.
Apr 15, 2017 | Washing Machines
New Hall Sensor & Rotor and code LE with some ringing noise
The LE code is displayed when the motor goes into an overload situation, if you have changed the Hall sensor and rotor, the only other problem is the stator overheating which will bring on the LE display.
Check the stator assembly, replace is faulty.
Dec 18, 2013 | LG WM2801HWA 4.5 cu. ft. Front Load Steam...
My Electrolux front load washer does not fill with water in the rise cycle and beeps and displays "draining, no water"
If this is a brand new product, I suggest that you MUST call for warranty assistance from their depot.
This can be related to failure or error of the controller, fault in the inlet or water level sensor which must be done free of cost.
Feb 12, 2013 | Electrolux EIFLW50LIW 4.2 Cu. Ft. Front...
Washer display LE error. We have Washer/Dryer LG WM3632HW and sounds like other LG Washers have same problems.
I managed to locate the users manual for your machine here:
http://dl.owneriq.net/e/e181c175-9ece-42cb-9132-c4ab23475aef.pdf
I took the following text from the manual (it also gives you a step by step guide to cleaning the filter):
The water inlet filter
• "lE " error message will blink on the control panel when water does not enter the dispenser.
• If your water is very hard or contains traces of lime deposit, the water inlet filter may become clogged.
We recommend cleaning it every few months.
I hope this helps you out.
Best regards,
Ian
Nov 29, 2009 | LG Washing Machines
Have error code f 02 showing up on my Duet fronload washer, during rinse and spin cycle
F/02
DURéE EXCESSIVE DE LA VIDANGE
If the drain time exceeds eight minutes, the water valves are turned off
and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
Si la durée de l’opération de vidange est de plus de huit minutes, le système commande
la fermeture des électrovannes et l’affichage du code “F/02” clignotant. Appuyer deux
fois sur la touche PAUSE/CANCEL pour commander l’effacement.
NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus
tard le code “F/02” sera affiché.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer will not go through a complete cycle. It flashes F2 and will sit on SUD for ever as well as run on the last 1 minute for an hour. Help
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed. Si la durée de l’opération de vidange est de plus de huit minutes, le système commande la fermeture des électrovannes et l’affichage du code “F/02” clignote. Appuyer deux fois sur la touche PAUSE/CANCEL pour commander l’effacement. NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus tard le code “F/02” sera affiché. Possible Causes / Procedure 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Jun 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LE flashing symbol where time left should be
LE is a locked motor error. 95% of the time this is just a bad hall sensor (motor position sensor). A technician should be able to ohm out the hall sensor to make sure.
The part is relatively inexpensive and easy to replace. Hope this helps, please rate my solution.
Jan 09, 2009 | Washing Machines
Error message when trying to wash
Unplug the machine and spun the drum few times by hand, wait 10-15 min. and plug it back. Good luck!
Aug 06, 2007 | LG WM-2077C Front Load Washer
LG WM-2277HW Front Load Washer Logo
109 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
