Question about Denon AVR-1600 Receiver
Avr-1600 bought brand new several years ago....about a year old it decided to not power up anymore. little light comes on ...blinks ...then off...checked all connections including the speakers. no luck.. any ideas or should I take to land fill?
  • phillnz Feb 08, 2009
    can someone give me the specs of the power transformer plz
  • 3130 Answers
SOURCE: No Power
I mwas gonna suggest that you need the speakers attached but you stated later that it did the same thing with the speakers attached. The unit switching off after it checks its self is NOT a normal thing. TAKE IT BACK BEFORE ITS TOO LATE!! GOOD lUCK
Posted on Jun 18, 2006
  • 3130 Answers
SOURCE: Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Posted on Jun 05, 2007
  • 54 Answers
SOURCE: Denon AVR-1601
This is a very common problem with denon receivers of the 2001-2-3 vintage. On almost every one, there are 4 little "surge" resistors in the power supply. These werent quite robust enough from the factory and one day would just burn open for no reason. Well, actually there is a reason, the "surge" that happens every time you power the unit up eventually weakens the resistors and then they pop. You need to take this to a denon service shop as I GUARANTEE they have seen this before. They need to check resistors in the picture, locarde above the **** rectangular connector. Resistors numbers R141, 142, 148, 149: 75f69d7.jpg These resistors when measured, should be less than 10 ohms each. If they are more, then they are blown. If they are blown, then have the shop check the channels for blown output transistors. If the outputs are OK, then these resistors should be replaced with 1 ohm 1/2 watt metal -film flameproof resistors. You might need to be prepared for a large bill, because the entire unit must come apart to replace the resistors, however, just checking them takes only about 10 minutes... Good luck and don't try this at home. Rob
Posted on Apr 08, 2008
  • 624 Answers
SOURCE: Denon AVR-3802
I have repaired many of these Denon receivers over the last few years.
Since the headphones work, that means if you dis-connect the speakers it will turn on and not go into protect (when power cuts off a few seconds after turning the unit on).
The most likely problem is a bad speaker. to find out which speaker is causing the problem, do this.
Start out with just one speaker connected and then turn on the unit. If it turns on and plays music, you know that speaker is good.
Now turn the unit off again and add another speaker and keep the first speaker connected. Once again, if the unit plays, that speaker is also good.
Keep doing this same procedure one speaker at a time. As soon as you connect a speaker and then try to turn on the unit and it goes into protect, the speaker you just connected is bad.
To confirm that this speaker is the bad speaker, dis-connect all speakers and only plug the suspected bad speaker into a speaker jack that worked with one of the other speakers.
If the unit still goes into protect you know then that you have found the bad speaker.
If the unit still goes into protect, that speaker is bad and you will need to take it in for repair or replace it.
make sure you use 8 ohm speakers. if i remember correctly these Denons can use 6 ohm speakers, but those are harder to find and most home speakers are 8 ohms.
If the unit does not go into protect and that suspected bad speaker plays in one of the other speaker jacks, what you really have is a bad channel in the amplifier, the channel that the suspected bad speaker was previously connected to.
If you find out you have a bad channel, you will need to take it in to an repair center. Preferably an authorized Denon service center. There are not very many of those around. I work at the only authorized Denon service center in the entire state of Michigan.
If I can be of more assistance, don't hesitate to ask. And a good rating is always appreciated. :)
Posted on Jun 22, 2008
  • 93 Answers
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Posted on Nov 06, 2008
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
Red Power Light flashes 3 times
3 blinks 3.3v SOS D Board. This is the fault. That's SOS board has the fault. Check this to know more details.
Jan 07, 2013 | Televison & Video
Bought agojama battery drill from homebase about 5 years ago and dropped it about a a year ago and I have been unable to find a replacement battery
Im from the U.S. and never heard of that brand even ?? But generally a 5 year old cordless drill is basickly disposable. The batterys packs back then were NiCad and now there lithium ion. Huge improvementshould definetly look it up. But even without that little fact for the cost of a replacement battery you can find a new drill with two new batteries that are much better..
Jun 03, 2012 | Hand Tools
I have a LC-37HV4U that I bought brand new several years ago. I have had no problems with it until the other day when I turned it on and all I got was a steady red power indicator light. No picture at...
check the copactors on the main power board if any are blown the top of it will be raised they look like little bateries replace them with same value and same way
and if you still think it is the inverter board one of the resistors are O/C
Nov 28, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
I bought a Dymo label printer several months ago and just attempted to set it up for use. The ac adapter shows a blinking green light, however there is no light on the printer, and it does not appear that...
If you only purchased it a few months ago then why not return it...? They generally come with 3 year warranties, so unless you bought it 2nd hand you should be fine...
Nov 24, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Bought 2 several years ago. Neither one cools
What type of refrigerant is running with these units? what Ambient temp do they work in? what is the temp of the Air off.
Jun 09, 2009 | Maytag M6Q10F2A Air Conditioner
Blinking Clean and Rinse lights on Maytag PD8460AWN
My Maytag PDB4600AWN quit working with a flashing CLEAN light and RINSE only button. I took off the bottom panel and took out the electrical diagram.
I ran the diag test, tried pulling power, and a series of other ideas just to see if the error always pointed to the same thing and it did. It's the motor pump. My Maytag is 10 years old. Not sure what yhe life span of such things are. My Mom had a Kenore dishwasher that ran 17 years. Don't think that happens anymore. I bought my Maytag laundry washer and dryer at the same time as my dishwasher and they have trouble now also. Guess those TV commercials were a little on the iffy side of truth. Hee heeeeeeeeeeeee. :)
I think I'll just buy a new dishwasher. The repair guys bill will be high enough that I may as well
Feb 06, 2009 | Kenmore Dishwashers
TV won't come on
unplug it for 10 minutes then turn it on at the console(not the remore) and hold the power button in for 15 seconds. this resets most apex tv's
Oct 06, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Just tried calling the 1800 number
It's really sad that Hitachi has resorted to not taking care of it's customer's anymore regarding the obvious light engine DEFECT! Several of us on fixya dealt with Hitachi's customer relations department, got a new light engine and our set is like brand new. I personally sent out over 80 suggestions related to this problem. I have to believe that they've stopped due to the number of us that have had problems and the $$ it's cost them...too bad! Make a product that last like they use to! This is our second Hitachi TV and it will be our last. They did send a new light engine and it fixed our set which looks great...for now. Having said that, there are too many other, reputable companies to go with that will take care of the customer long after the sale.
We just bought a 42" Samsung for our master bedroom and we were sure to get the 4 year extended warranty. In the past, we would have never considered getting the extended warranty because things lasted. Not anymore!
I'm certainly not one of the "conspiracy theory" types but one would have to wonder. Over the past 10 years, my husband and I have bought 2 Hitachi sets that cost around $8000 total. Do they now have a "short shelf live" so to speak to keep us buying a new set every 3-4 years?? I have a friend that has a 25" Sanyo that she bought at Kmart 10 years ago and it's still going strong. Makes you wonder...hummmm!
May 01, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Denon AVR-1600 Receiver Logo
59 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
