We bought a new laptop yesterday, and when we tried to connect it up to our router, it let us connect, but my daughters laptop was no longer connected. everytime we tried to re connect it, it says cannot connect to network. we tried everything, but it does not work. when we click on diagnose problem, it says it cannot varyfy uthentification, because of a timeout. no one seems to know what this timeout means. can u help
  • 849 Answers
You must have same workgroup to connect the computers along each other.
Posted on Oct 21, 2008
I have a toshiba Satellite c655. I bought it for my 12 year old daughter about 6 months ago. she was using the internet everyday and then about a week ago it wouldnt connect to my router. The laptop...
IS THE CONFIGURATION OF SECURITY ON TOSHIBA WIRELESS ADAPTER SET TO WEP INSTEAD OF WPA OR VISA A VERSA CHECK THE SETTINGS ON YOUR OTHER LAPTOPS TO SEE IF THEY'RE THE SAME
Jan 21, 2011 | Toshiba Satellite C655S5056 Notebook PC
I have a windows xp laptop computer that is not very new. I bought a netgear router and hooked it up to my desktop computer and was able to get wi-fi for my daughter on her i-pod. Now I am trying to get...
Pretty simple. It should be set to auto discovery. As long as the WiFi is working ie switched on you shoyuld find your home network pretty easiily. You do need ot knwo the SSID (the name of the network adn teh pasword. Right click on the wireless icon in teh tray to the bottom right adn show the list of netwoprk sits found. One of those should be yours. Simply 'connect' to the network adn entire the Passphrasethat was preassigned when you set up the network an it should automagically connect.
Jan 13, 2011 | NetGear WGR614 Wireless Router
G'day Govinda123 We've bought a new Acer Aspire one laptop. When we try to connect to the internet, it picks up our network with excellent connectivity, but when we type in the network security key to...
I just baught a new Acer Aspire 1551-4755 yesterday, I spent 4-5 hours on the phone with the router people and they did everything they could to help, but there is something wrong with the acer software and acer will not help unless you pay them $100 for support.
Nov 01, 2010 | Computers & Internet
I have a Belkin G F5D7234-4 v4, I had no problem with setup, and my daughters IOPD Touch connected easily. Yesterday my other daughter brought her laptop over and hooked into our router. Now the...
Connect Modem - Router - Computer ( Wired)
Open RSP by typing 192.168.2.1 on the Address bar of the internet Exlplorer
On the Left Click Wi Fi Protected Setup (WPS)
Leave the password blank and click Submit
Disable it And Click Apply Changes
Then On the left Under wireless click channel and SSiD
Change the SSiD into a different Name (and click apply changes
On the left under wireless click Security
Select the security type as 64 Bit WEP
On the Key 1 - Type a 10 Digit number(this is your password )
Click apply changes
Connect to this network on your wireless devices
Apr 10, 2010 | Belkin F5D7234-4 Router
Every time my daughter uses her laptop, my pc says
Either unplug the router from power source for 10 seconds and plug back in to reset.
Or you may have an ip address on the pc itself that is conflicting with your daughter's ip address. Dynamic ip address are set so they don't interfere with each other. We use 4 different pc's on one router in our home.
You can change the ip address of your computer by going to start menu, then run, then type ipconfig /release, then type ipconfig /renew and it will give you a new one.
Or you can access the software and settings of the router itself by opening up an internet page, go to address bar and type 192.168.1.1 and hit enter.
It should bring you inside your router so you can check and switch any settings.
Nov 17, 2009 | NetGear WGR614 Wireless Router
I bought this router 2 days ago. I pluged in the phone socket (with micro filter), and into mains,it worked perfectly on my daughters' (each daughter has a laptop - all work)laptops, and one of my desktop...
1) Make sure there is no low-pass filter from the phone line to the wall - it should be directly connected.
2) The laptop issue has nothing to do with the wireless router if it's actually connected. Try pinging the router. Open the command prompt. type ipconfig. Look at the laptop's IP address and the gateway. Try pinging the gateway (ie ping 192.168.1.1). If the ping works, the connection is fine.
3) Can you open a browser window but not connect to a web page? This is due to a connectivity issue. If you can't even open a web page for whatever reason, its a problem with the laptop, not the connection. Hope this helps.
Nov 08, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Wireless connectivity
You probably set an access list on your router
connect to Router using a LAN cable and check if you can browse.
Then
Check your access list on router.
Disable it if you cannot add your PC wireless adapter MAC address
Jan 04, 2009 | Computers & Internet
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Laptop
It really depends on what "modem" Orange provided you with and how your personal PC is connected to the modem.
If the "modem" provided by Orange uses WiFi (such as Livebox) networking, then it is a matter of setting up your daighter's laptop to access and use the Livebox WiFi Network. In this case no router is needed since your modem is also a router.
If your PC is connected via Ethernet port to the "modem" and Orange's "modem" is a single Ethernet output port, you would need an AP/Router (Wireless since I am presuming the your daughter's laptop would be accessing the Internet wirelessly) such as the LinkSys WRT54G.
If your PC is connected via USB port to the "modem" and Orange's "modem" has only a USB output port (no Ethernet), you need to make your PC as the default gateway/software router and share your PC's Internet connection. If you are connecting your daughter's laptop using Ethernet cable, then you don't need a WiFi AP/Router but an ordinary hub. If on the other hand the new laptop would connect wirelessly, you would still need something like the WRT54G.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | 2wire (1000-400108-001) Router
Computers & Internet Logo
David Payne
David Payne
