Question about Casio QV-R41 Digital Camera
Tranform what do i need to transform pic from cam to pc ?
  • 849 Answers
A interface cable and camera drivers with application software.
Posted on Oct 22, 2008
Where is the transformer located on a turbochef tornado
There are 2 hv transformers. If you take the right side cover off, they are towards the top of the unit. I think you need to take the top cover off, as well, to replace them. If you google turbochef tornado, there are very detailed repair manuals available for free. They shouldn't be hard to replace yourself. You might need to replace the capacitor (s) too. If it won't stand up on its own without falling over then good chance that is shot too. Remember to take a picture before you take everything apart, so you know how it goes back together. Remember to unplug!!! :). These are pretty easy to work on yourself. A service call will cost you at least $500 to replace a fairly cheap part. I learned the hard way. Below is a pic of a transformer, capacitor and mag. They were all bad. Eventually a bad mag will ruin your transformer and capacitor. 8ac8c2ce-4199-46ea-9981-2a2ee5dc9570.jpg c10f5a3f-ab72-45d5-94a0-8faed3674ea8.jpg 1f8362be-530d-497c-83d4-1ba6d05c9557.jpg
Jun 28, 2014 | TurboChef TORNADO Electric Oven
Change 220v to 110v
You will need a transformer. If the appliance is 220V to start with, you need a step-up tranformer, that is, 110V supply UP to 220V output. The other way round, a step-down transformer.
They are sold at hardware outlets and electronics suppliers like RadioShack.
Feb 13, 2014 | PfaFF Tiptronic 2040
How easy is it to replace an intermatic ML300RTW malibu tranformer?
Question is not 100% clear.
Add a comment any time, and that sends email, and I will respond with more information if needed.
1) Are you trying to repair a transformer?
I do not know of any repair for the transformer, or available parts sold to repair transformer, although the product does have a warranty, and Intermatic might have a repair protocol for the transformer.
http://www.intermatic.com/customer%20service.aspx
2) Are you replacing existing transformer with a new transformer?
The transformer plugs directly into outdoor outlet, and wires are connected to A and B terminals.
Open following link to read how to set up and use transformer in troubleshoot-format:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Sep 17, 2011 | Intermatic Malibu 300W Power Pack...
Need power cord tranformer for my computer speaker system. plug on one end other end 3 pin system on othe Transforms 110v down to I guess 12v. not sure
you'll need electrical specs of the transformer (current and polarity) for the speaker system and mechanical connector spec. At the very least a model and number.
Mar 21, 2010 | Audio Players & Recorders
Radio works with the batteries but not the mains all terminals and connections are ok any ideas ?
Check glass fuse inside near transformer, if this is ok, there is a thermal one on the tranformer windings itsself where you need to cut the tape off the transformer windings doing with caution. Not to cut the transformers windings, once located desolder and replace the part from RS components or Maplins. I had the same problem as you, I bypassed this on the tranny and mine is fully working. This item is a safety feature for the transformer.
Nov 10, 2009 | Dewalt DC011 AM/FM Radio
I have the 600-water Malibu transformer. Some nights one of the loops of lights will go out. The other loop stays lit. I might go out 30 minutes later and both loops are lit. I am still well under the...
Check for a loose connection where the problem "loop" connects at the tranformer.
Also, swap the "loop" connections to the tranformer. If the problem still persists replace the wire run. Sometimes wire gets damaged internally and visual inspection will not reveal that.
If the problem occurs in the other loop after the swap, then you probably have a bad connection inside the transformer. If that is the case, you won't be able to use that connection as the transformer has no user servicable parts.
Also, if the tranformer in under 5 years old, it's still under warranty.
Jul 06, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Mitsubishi CS-40503 Zapped by high voltage
the only option is to bring your x-former as sample or take a pic of it and post it.
Mar 26, 2009 | Mitsubishi CS-40503 TV
Logitek transformer for force 3D
The power supply is Logitech Model # GAD-SLU-240A8 P/N 190057-1000 OUTPUT IS 24V-----0.75A The output connector is positive center, negative outer ring.
Oct 02, 2008 | Logitech WingMan Force 3D Joystick
Casio QV-R41 Digital Camera Logo
42 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
