Question about Freezers
Not cold enough?
Two weeks ago I filled my freezer up with meat and since then it appears to be working overtime with the fan and motor constantly going day and night.
I have found that the temp is 0 degrees and some food I added on Saturday (chicken necks) are still not properly frozen.
Any suggestions
  • 1 more comment
  • Marina Van Dyk Oct 20, 2008
    An upright freezer purchased 12 years ago. No previous problems at all
    Thanks
    I must add an upright frost free freezer unit on it's own, no fridge.
    Thanks for that. I will get hubby to move it and check the circulation and cleanliness of the condensor etc.
  • 61 Answers
Is this a chest freezer or upright frost free fridge freezer . nead more info
Posted on Oct 20, 2008
  • john berlinghof Oct 20, 2008
    an upright frost free freezer neads a lot of air circulation around the product , also they are under disighned for acualy flash freezing large quantitys of product. the manufatuares rely on you dringing home preveously frozen products. as long as there is enough air circulating around your products the freezer will eventualy freez them . remember the compressors capacity is aprox 400 btu.s witch is about 400 lbs water 1 deg f per hour without outside influences . ie defrost systems. insulation . surounding temps. enshure ther is no dust build up uder or behind the freezers condesor and if it has a condensor fan enshure good circulation threw condensor. to remove heat from products the freezer has to be able to dicharge that heat. hope this makes sence and helps you
My frigidaire upright freezer has been working fine until about 2 weeks ago. Now pizzas aren't freezing and freezer corn is soft and i put a ham in it and that was a week ago and it is not froze.
There should be a temperature adjustment inside the freezer somewhere. It will look like a slider or a dial, and be labeled something like "Colder" and "Less Cold" on opposite ends of the scale. If this is set to its coldest setting, and the temperature still is not cold enough to solidly freeze food (ideally, a freezer's temperature should reach ZERO degrees Fahrenheit), then the unit needs to be serviced by an appliance repairman.
Nov 30, 2017 | Frigidaire Freezers
Upright Freezer not cold enough
Honestly it sounds as if you have a sealed system issue, most likely low on freon.
Jun 13, 2012 | Freezers
I have a 20 cf upright GE freezer that isn't
it may be froze up, and require a defrosting. use a portable fan to speed up this process , also make sure the fan in the freezer compartment is working, with a little work and a zoom spout oiler, or some light motor oil, the motor can be sparked back to life.. freeze ups are common with the high humidity we are having these days.. jay the pool pump motor repair guy longwood Florida
Aug 02, 2011 | GE Freezers
Meat on top two shelves unthawed while bottom two shelves is frozen and has stayed frozen for three days. Air does not appear that cold coming out of top of freezer.
hi... is the evap fan motor running in the freezer ? if it is then check the the evap coils if it is completely frosted then u need to check the defrost timer .if that is good then check the defrost limiter that is on the evap coils and if that is good then u got a bad defrost heater. now if there is frost only on the bottom or top of evap coils u may have sealed sys problem if u got an ? feel free to write me..
Apr 19, 2011 | Kenmore Freezers
Freezer is not getting cold enough. For example, meat is still frozen but ice cream is soft.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 01, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
Jan 02, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Some food is thawing in my chest freezer
these frigidaire made freezers are notorious for having restrictions in the sealed systems that will cause exactly what your describing.
what happens is oil moves around in the freon system and pools up in the capillary tubes and the freon is not able to flow properly. if the unit is under 5 yrs old then should be inwarranty to sears. if its over 5 then probably cheaper to purchase a new one..
Dec 19, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Hotpoint FZA50 Freezer not cold enough
try it on max setting. lint clogging up stuff in the back? needs defrosting? low on refrigerant (freon)? call repairman for that last one
Jul 10, 2007 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Freezers Logo
200 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
