Canon ES550 8mm Analog Camcorder
Problem for Canon ES550 8mm Analog Camcorder
Jumpy Playback Through TV
By Pepelapew on Jun 24, 2006
I have an old Canon E520 that I bought on Ebay. When I connect the camcorder to the TV via and RCA cable and play the tape, the video is jumpy. The audio is fine, but the video jumps around a lot. Is there any way to fix this. Do the heads need to be cleaned?
Solution #1
posted on Jul 21, 2006
Somewhat Helpful)
hardrocko
Rank: Guru
Rating: 85%, 922 votes
First you should try a couple other tapes to make sure they all do it. It could be tape damage on the tape you are using. If you remove the tape from the unit and look at the part which gets inserted first you will see a small latch on the front side of the door. If you depress the latch you can open the cover over the tape. Be very careful and don't touch the tape! Look at the tape for damage. If it is perfectly smooth, like a mirror, it is OK and the camcorder has a problem. If the tape is OK you probably have a tape path problem or the unit could be dirty. Cleaning the heads would be the easiest solution to try but if you are not familiar with the process you could do more damage than good. If you know how to properly clean the heads, certainly do that first. If that does not solve your problem either a tape guide is not adjusted properly or the tape is not loading fully or properly in the tape path. Either way it isn't going to work until it is repaired. I'm guessing that repair would be beyond your skills. You stated that you bought it off Ebay. You should contact the person you purchased it from no matter what is wrong with it because if they presented it as a working unit they were less than truthful. Good luck.
Was this helpful?
Yes
No
Solution #2
posted on Dec 27, 2006
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
but the problem sounds to be that the playback on the LCD is fine while the TV playback is problematic. I am currently having a similar problem using the three to three connection to the TV: audio is fine picture is completely distorted. I tried to adjust NTSC playback mode and changed it to NTSC and not to PAL TV, but nothing changed. Can you only use S-video lines with these cameras? sony dcr
Popular Solutions for Canon ES550 8mm Analog
Questions and Unsolved Problems for Canon ES550 8mm Analog
Do you recommend Canon ES550 8mm Analog Camcorder?
Answer
Answer
when i try to record on my samsung camcorder the recording is very fuzzy. What can i do to fix it?
Answer
How can i fix my video camera when it wont turn on even with full battery?
Answer
Our Pro HD camera is occasionaly giving a 'record error' message and then flipping straight to... (More)
Answer
can you help me get aiptek software
Answer
how can i record tapes onto my camera? ive thought it out and it hasent quite worked, im not sure if... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon ES550 8mm Analog...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 756
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
