Question about Frigidaire FGF378AC Gas Kitchen Range
Turns my pots black!
We installed this oven ourselves and never had it calibrated. Now all of our stainless steel pots and pans have turned black from the flames on the cooktop and anything that goes into the oven also comes out black (the dishes - not the food!). Is there anything we can do to solve this problem?
  • dmccarthy121 Nov 03, 2008
    same EXACT PROBLEM WE JUST BOUGHT AND MY HUSBAND INSTALLED flame is blue and i try not to use it high but the black is so annoying i want an electric now . never had this problem help!
    Habit-Forming:
  • 171 Answers
Yes, you can open the air vents to each one of the burners, this is locate as the burners met the valve that turns them on.
Posted on Dec 08, 2008
I get an E 1 message on my Kambrook induction plate. I am using a stainless steel bottomed pot.
many stainless steel pans are non magnetic . test your pans with a known good magnet . if the magnet does not stick then the pan will not work .they need STEEL in the bottom
Nov 11, 2017 | Stainless Coffee Makers & Espresso...
What are frying pans made out of?
They can be made out of a lot of things but most are copper, Teflon or tin.
Jan 10, 2013 | Home
I have the porcelain coated pans and the kids burnt chilled cheese and just can't seem to get it clean now
You can use spray-on oven cleaner, such as "Easy Off" or any similar store brand. Do not use oven cleaner on Aluminum pans, pans with non-stick coatings, or pots/pans with plastic or rubber handles. Wear rubber gloves when working with oven cleaner. It is a very powerful cleaner and can burn your skin.
  1. Put the pan in your empty kitchen sink.
  2. Spray it on generously with oven cleaner.
  3. Leave it overnight, 8 hours or so.
  4. In the morning thoroughly rinse and wipe all the areas you sprayed, including the sink.
You should have a clean pan and a clean sink. Refer to the oven cleaner's label for further instructions and safety hazards. Choose the type of oven cleaner that suits your needs. In my experience, "Fume Free" oven cleaners take longer and don't work as well. Seemingly, the more noxiously fumed cleaners, ie ones containing Lye (Sodium Hydroxide), work better and faster.
This works for porcelain coated pots/pans, stainless steel, steel, glass, etc. Do not use oven cleaner on aluminum pans, pans with non-stick coatings, or pots/pans with plastic or rubberized handles.
Apr 02, 2011 | Vacuums
Not cleaning very well
You can look at the powder that you are using and try some other brand. I am not sure what you are cleaning. are you cleaning stainless steel. or are you cleaning pot and pans?
Feb 20, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a new induction cook top. When using for the first time I found an F or P appeared next to the element I was using. I have bought stainless steel cookware specifically to use. The user manual...
Stainless steel (or Aluminium) cookware will not normally work with an Induction cooker: Induction cooker need cookware that have a certain amount of metal especially at the bottom of the pot or pan.
An easy way to check if the cookware is suitable is to use a small (fridge) magnet: if it stick to the pot/pan then it is very likely that the pot/pan is suitable for induction 'magnetic' cooking!
Hope my small hint is of assistance and if so, vote accordigly!
Oct 03, 2010 | Westinghouse Microwave Ovens
What causes my pots and pans to turn black on the botom when cooking on a gas stove? Many thanks
depends on the pots. Some is because of they type of metal. The metal turns black because actual fire will turn it when it touches the medal. Others could be grease. Some dish soaps dont get all grease off the pot. Specially if you use dish washer. Try soaking them and see if they will come clean. Dawn dish soap works great or there are products you can buy just for that purpose. good luck
Jan 07, 2010 | Ovens
Hello My gemini top burners cycle on and off,
The burners are designed to cycle on and off, it is technology that helps to keep from burning food. If you are using the correct pan to burner size ratio and high setting on your burner, the water should boil in the normal time. Don't watch the pot (just kidding)
Nov 30, 2009 | Maytag Gemini 30" Self-Cleaning...
Cleaning the stainless steel griddle??
We buy DeBruce Polish at debruce polish.com this stuff really works!!
Mar 28, 2009 | Thermador Professional Series PO301...
How to remove black grease and smoke marksfrom brushed stainless
In order to avoid damage to the surface, my favorite is petrol (gasoline) to melt the muck and then a standard non abrasive detergent cleaner to get rid of the smell of petrol. Alternatively, you can try a proprietary oven cleaner (one that doesnt need the oven to be hot)
Mar 24, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Frigidaire FGF378AC Gas Kitchen Range Logo
237 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
